查看: 2629|回复: 0
低温等离子体处理及丙烯酸接枝改性膨化聚四氟乙烯薄膜
发表于 2012-6-22 10:53:08 |江苏| 显示全部楼层 |阅读模式
陈亏[1,3] 高晶[1,3] 俞建勇[2,3] 还伟海[4] 马一梓[4][1]东华大学纺织学院,上海201620 [2]东华大学现代纺织研究院,上海200051 [3]纺织面料技术教育部重点实验室,上海201620 [4]江苏闳业机械有限公司,江苏盐城224043
摘 要:采用He等离子体对膨化聚四氟乙烯(ePTFE)薄膜进行表面亲水处理,并引发接枝丙烯酸单体实现持久亲水改性。实验探究了不同等离子处理工艺和接枝工艺对ePTFE薄膜亲水性能的影响,并利用接触角、X光电子能谱(XPS)进行表征。研究结果表明,等离子体预处理后,ePTFE薄膜表面的接触角由145°降至102°;再接枝丙烯酸单体,表面接触角进一步降低,且亲水性改性效果持久。确定了等离子体预处理的优化条件:He,100 W及处理时间90 s;接枝丙烯酸改性的最佳工艺:丙烯酸浓度30%(vo.l),接枝温度70℃,接枝时间3 h。XPS结果显示,改性后ePTFE薄膜表面F/C元素比从1.960降至0.853,O/C元素比从0提高至0.147,说明氟元素被含氧基团部分取代,这是ePTFE薄膜亲水性改善的根本原因。[著者文摘]
关键词:表面改性 聚四氟乙烯薄膜 低温等离子体 接枝共聚 亲水性
分类号: TQ316.6[著者标引]文献标识码:A文章编号:0438-1157(2011)04-1170-07栏目信息:材料化学工程与纳米技术
Surface modification of low temperature plasma-pretreated ePTFE film by AAc graft copolymerizationCHEN Kui,GAO Jing,YU Jianyong,HUAN Weihai,MA Yizi1School of Textiles,Donghua University,Shanghai 201620,China;2Modern Textile Institute,Donghua University,Shanghai 200051,China;3Key Laboratory of Textile Science & Technology,Ministry of Education, Donghua University,Shanghai 201620,China;4Hongye Machinery Co.,Ltd.,Yancheng 224043,Jiangsu,ChinaAbstractTFE adheres poorly to other materials due to its low surface energy and chemical inertness,which leads to failure of PTFE in many industrial applications.To spread the applications,numerous methods for surface modification have been developed to activate the PTFE surface for improving its wettability and adhesion ability.This study focused on the surface modification of expanded poly(tetrafluoroethylene)(ePTFE)film by a two-step process based on low-pressure plasma treatment followed by acrylic acid(AAc)graft copolymerization.The influences of different plasma treatments and graft copolymerization conditions on the hydrophilicity of film surface were studied.The wettability of the ePTFE film surface was determined by water contact angle,and the surface elemental compositions and the type of functional groups on the surface of the treated ePTFE samples were evaluated by X-ray photoelectron spectroscopy(XPS).The results indicated that the contact angle of ePTFE film declined from 145° to 102° when it was only treated by plasma treatment.After AAc grafted copolymerization,the contact angle decreased further to a smaller value.And the wettability of the film was improved obviously and kept constant.The condition of plasma treatment was He,100 W,90 s.The condition of AAc graft copolymerization was 30%(vol.),70℃,3 h.XPS analysis showed that the element ratio of F/C declined from 1.960 to 0.853,while the element ratio of O/C rose from 0 to 0.147.The result indicated that plasma treatment could greatly change the surface chemistry as well as morphology of ePTFE films.The surface roughness increased with plasma treatment time.From XPS measurements,it could be seen that the polar hydrophilic groups had been successfully grafted onto the ePTFE surface.The inert fluorine elements were partly replaced by oxygen polar groups,which was the fundamental reason for the improvement of hydrophilicity of ePTFE film.[著者文摘]
Key words:surface modification; ePTFE film; low temperature plasma; graft copolymerization; wettability
低温等离子体处理及丙烯酸接枝改性膨化聚四氟乙烯薄膜.pdf
405.56 KB, 下载次数: 0
GMT+8, 2026-8-7 14:39 , Processed in 0.351726 second(s), 10 queries , Redis On.
