查看: 2261|回复: 0
冶炼烟气制酸中稀酸泵机械密封的探讨与使用
发表于 2012-6-23 11:08:54 |江苏| 显示全部楼层 |阅读模式
高建涛 缪应革云南驰宏锌锗股份有限公司曲靖锌厂,云南曲靖655011
摘 要:分析冶炼烟气制酸中稀酸泵密封存在的问题,研究解决问题的方法,提出相应改进措施,并介绍了改进后的效果。[著者文摘]
关键词:聚四氟乙烯 摩擦体 摩擦力 石墨轴套
分类号: TH136 TQ051.21[著者标引]文献标识码:A文章编号:1003-8884(2010)06-0035-02栏目信息:开发应用
Discussion and Application of Mechanical Seal of Dilute Acid Pump in Acid-Making with Smelting GasGAO Jian-tao,MIAO Ying-geQujing Zn Branch,Yunnan Chihong Zn & Ge Co.,Ltd.,Qujing 655011,ChinaAbstract:This article analyzes the problems existing in mechanical seal of dilute acid pump in acid-making with smelting gas,studies the solution to problems,suggests the corresponding improvement measures and introduces the improved effect.[著者文摘]
Key words:polytetrafluoroethylene(PTFE); friction body; friction force; graphite bushing ring
冶炼烟气制酸中稀酸泵机械密封的探讨与使用.pdf
132.52 KB, 下载次数: 0
GMT+8, 2026-8-7 14:37 , Processed in 0.027754 second(s), 9 queries , Redis On.
