查看: 3520|回复: 2
PTFE及在化学电源和燃料电池中的应用问题(Ⅰ)
发表于 2012-6-23 11:15:56 |江苏| 显示全部楼层 |阅读模式
夏熙 新疆大学应用化学研究所,新疆乌鲁木齐830046
摘 要:聚四氟乙烯(PTFE),特别是PTFE薄膜和板材,广泛用于各种工业领域。在化学电源与燃料电池中,PTFE主要用作粘结剂。在PTFE研究中,主要是针对PTFE薄膜和板材的改性,作为粘结剂却研究不多,但对前者的研究对于后者的应用可能有所借鉴。[著者文摘]
关键词:聚四氟乙烯(PTFE) 表面改性 粘结性 亲水性
分类号: TM911 TM912[著者标引]文献标识码:A文章编号:1001-1579(2010)05-0256-03栏目信息:本刊专稿
相关文献:主题相关
The applications of PTFE in chemical power sources and fuel cell ( I )XIA Xi Institute of Applied Chemistry, Xinjiang University, Urumqi, Xinjiang 830046, ChinaAbstractolytetrafluoroethylene(PTFE), especially PTFE thin film and plate, was wildly used in many kinds of industrial fields. In chemical power sources and fuel cell, PTFE was mainly used as adhesive. The studies of PTFE were mainly aiming at the modification of PTFE thin film and plate; the researches as adhesive were a few. The research to the modification may had some reference to the application as adhesive.[著者文摘]
Key words:polytetrafluoroethylene(PTFE); surface modification; cohesiveness; hydrophilicity
PTFE及在化学电源和燃料电池中的应用问题(Ⅰ).pdf
266.17 KB, 下载次数: 0
售价: 1 氟币  [记录]
发表于 2013-2-26 14:53:25 |中国| 显示全部楼层
没有氟币了,好想要啊。
楼主如果想要赚氟币,不妨看这里:http://bbs.myptfe.com/thread-4684-1-1.html  详情 回复 发表于 2013-2-26 18:23
发表于 2013-2-26 18:23:32 |江苏| 显示全部楼层
GMT+8, 2026-7-14 22:54 , Processed in 0.172894 second(s), 12 queries , Redis On.
