查看: 2279|回复: 0
聚四氟乙烯纤维的制备与性能表征
发表于 2012-6-23 11:25:12 |江苏| 显示全部楼层 |阅读模式
聚四氟乙烯纤维的制备与性能表征
陈丽萍[1] 王耀武[2] 孙润军[1] 陈美玉[1][1]西安工程大学,陕西西安710048 [2]苏州大学纺织与服装工程学院,江苏苏州215021
摘 要:通过聚乙烯醇(PVA)作为载体,与聚四氟乙烯(PTFE)分散液配成混合溶液进行湿法纺丝制备PTFE/PVA初生纤维,成形后经烧结去除PVA。根据TG/DTG曲线选取烧结温度并判断烧结后样品的PVA去除程度,用扫描电镜观察了初生丝及烧结后纤维的形貌,同时通过强力测试得出烧结后试样的力学性能,结果表明,随着烧结时间的延长,烧结越充分,力学性能越优。[著者文摘]
关键词:聚四氟乙烯纤维 聚乙烯醇 烧结
分类号: TQ342.711[著者标引]文献标识码:A文章编号:1001-7054(2010)10-0024-03栏目信息:研究论文
Preparation and Characterization of PTFE FiberCHEN Li-ping,WANG Yao-wu,SUN Run-jun,CHEN Mei-yu1.Xi'an Polytechnic University,Xi'an 710048,Shanxi,China;2.College of Textile and Clothing Engineering,Soochow University,Suzhou 215021,Jiangsu,ChinaAbstract:The as-spun fiber of PTFE/PVA was prepared through wet spinning of PTFE/PVA mixing solution,the PVA component was removed from the resulting fiber by sintering.The temperature of sintering and the removing rate of PVA was set according to the TG/DTG curve.Simultaneously,mechanical property of the sintered sample was characterised by tenasity testing.The results indicated that the longer sintering,it could make sinter fully and the mechanical property well.[著者文摘]
Key words: PTFE fiber; PVA; sintering
聚四氟乙烯纤维的制备与性能表征.pdf
369.11 KB, 下载次数: 0
聚四氟乙烯纤维的制备与性能表征
GMT+8, 2026-8-7 14:36 , Processed in 0.520307 second(s), 10 queries , Redis On.
