查看: 2134|回复: 0
PTFE-SAN复合粒子在ABS中的分散及其对ABS燃烧特性的影响
发表于 2012-6-24 06:51:30 |江苏| 显示全部楼层 |阅读模式
肖高军 包永忠浙江大学化学工程国家重点实验室,杭州310027
摘 要:研究了种子乳液聚合制备的聚四氟乙烯/苯乙烯-丙烯腈共聚物(PTFE-SAN)复合粒子在ABS中的分散及其对ABS燃烧特性的影响。发现PTFE粒子在ABS基体中分散良好,并出现少量成纤TFE-SAN粒子的加入可促进ABS的塑化,但却使ABS的熔体流动指数减小,流动性下降TFE-SAN复合粒子可降低ABS的燃烧速度,并具有良好的防止燃烧过程熔体滴落的作用。[著者文摘]
关键词:聚四氟乙烯 丙烯腈-丁二烯-苯乙烯共聚物 分散 熔体滴落
分类号: TQ174.758[机标]文献标识码:文章编号:栏目信息:研究与应用
Dispersion of PTFE-SAN Particle in ABS and its Influence on Flaming Properties of ABSXiao Gao-jun Bao Yong-zhongState Key Laboratory of Chemical Engineering Zhejiang University,Hangzhou,310027AbstractTFE-SAN composite particles were prepared by seeded emulsion polymerization and used as the flame retardant modifier of ABS.The dispersion of PTFE-SAN composite particles in ABS and its influence on flaming properties of ABS were investigated.It is shown that PTFE-SAN composite particles are dispersed well in ABS,and are partially deformed into fibers after melt-blending.The fusion of ABS is accelerated as PTFE-SAN composite particles added,while the melt flow index(MFI) of ABS is significantly decreased after blending with PTFE composite particles.The addition of PTFE composite particles is efficiently decreased the combustion rate of ABS,and the modified ABS exhibites anti-dripping properties.[著者文摘]
Key words:polytetrofluoroethylene; acrylinitrile-butadiene-styrene copolymer; polytetrafluoroethylene; dispersion; melt dripping
PTFE-SAN复合粒子在ABS中的分散及其对ABS燃烧特性的影响.pdf
483.37 KB, 下载次数: 0
GMT+8, 2026-8-7 14:38 , Processed in 0.019878 second(s), 8 queries , Redis On.
