查看: 2888|回复: 0
R152a与R134a混合制冷剂替代R22的可行性研究
发表于 2012-6-24 06:53:24 |江苏| 显示全部楼层 |阅读模式
刘靖 程艳华河南理工大学,河南焦作454000
摘 要:制冷剂R407C和R410A是R22的主要替代物,它们的温室指数(GWP)值还较高,对环境仍然有一定的影响。本文对R152 a和R134 a组成的混合制冷剂进行了理论研究,通过分析该混和制冷剂的环境影响指数、温度滑移特性、热力学特性、安全特性和润滑油等问题,经理论循环计算并与R407C和R410A进行了对比,结果显示:由质量分数为50%的R152 a和质量分数为50%的R134 a组成的混和制冷剂对环境危害很小,具有合适的性能系数(COP)和排气温度,是一种润滑特性很好的优良近共沸制冷剂,在替代R22技术上完全具有可行性。[著者文摘]
关键词:二氟乙烷 四氟乙烷 R22 制冷剂替代
分类号: TB612[著者标引]文献标识码:A文章编号:1005-0329(2010)11-0070-04栏目信息:制冷空调
Feasibility Research on Using R152a and R134a Mixture as Alternative for R22LIU Jing,CHENG Yan-huaHenan Polytechnic University,Jiaozuo 454000,ChinaAbstract:The refrigerants R407C and R410A are the main alternative of R22,but their greenhouse index value(GWP) are also higher,still has a certain impact on the environment.In this paper,theoretical study on the mixture refrigerant composed of R152a and R134a is carried out.The environmental impact index,temperature-slip properties,thermodynamic properties,safety features and oil of the mixture refrigerant are analyzed,and compared all its performance with R407C and R410A by calculating a theoretical cycle.The results show that the mixture refrigerant composed of 50% R152a in mass fraction and 50% R134a in mass fraction is a very good near-azeotropic refrigerant mixture with less harm to environment,small temperature slippage,proper discharge temperature and good lubrication performance.So it is an entirely feasible alternative for R22.[著者文摘]
Key words:R152a; R134a; R22; refrigerant alternative
R152a与R134a混合制冷剂替代R22的可行性研究.pdf
301.02 KB, 下载次数: 0
GMT+8, 2026-8-7 14:36 , Processed in 0.342877 second(s), 8 queries , Redis On.
