查看: 2636|回复: 0
玻璃纤维/聚四氟乙烯复合材料的制备与性能研究
发表于 2012-6-24 07:22:20 |江苏| 显示全部楼层 |阅读模式
颜录科 李炜光 孙增智长安大学交通铺面材料教育部工程研究中心,西安710064
摘 要:通过高速混合、冷压烧结成型法用玻璃纤维(GF)填充聚四氟乙烯(PTFE)制备了GF/PTFE复合材料,探讨了GF用量对GF/PTFE复合材料拉伸性能和摩擦磨损性能的影响,用扫描电子显微镜(SEM)对复合材料微观结构进行了分析研究。结果表明:GF质量分数为15%时,复合材料耐磨性能最好,磨耗量不足1.0×10-3g/h,拉伸强度与常规干法混合制备的复合材料相比提高近30%,高速混合工艺使GF均匀分布于PTFE基体中,并可进一步细化PTFE粉料。[著者文摘]
关键词:聚四氟乙烯 玻璃纤维 高速混合 摩擦磨损
分类号: TM215 TQ327.3[著者标引]文献标识码:A文章编号:1009-9239(2010)04-0003-03栏目信息:研究与应用
Preparation of GF/PTFE Composites and Its PropertiesYAN Lu-ke,LI Wei-guang,SUN Zeng-zhiEngineering Research Center of Transportation Materials,Ministry of Education,Chang'an University,Xi'an 710064,ChinaAbstract:A glass fiber(GF) reinforced polytetrafluoroethylene(PTFE) composite was prepared by high speed mixing method and cold press and sintering technique.The effects of GF amount on the tensile strength and friction and wear properties of the GF/PTFE composites were investigated.The results indicated that the abrasion loss of 15%GF/85%PTFE composite was lower than 1‰ g/h;the tensile strength was increased by 30% compared to that made by normal dry mixing method.The microstructure of the composite was then characterized and analyzed by scanning electron microscope(SEM) which revealed that high-speed mixing method can solve the agglomeration problem of PTFE resin,making GF dispersed homogeneously in PTFE and further pulverizing the materials powder.[著者文摘]
Key words:polytetrafluoroethylene(PTFE); glass fiber(GF); high-speed mixing; friction and wear
聚四氟乙烯复合材料的制备与性能研究.pdf
300.17 KB, 下载次数: 0
GMT+8, 2026-8-7 14:40 , Processed in 0.026423 second(s), 10 queries , Redis On.
