查看: 4288|回复: 0
铝酸酯处理实心玻璃微珠填充聚四氟乙烯复合材料的研究
发表于 2012-6-24 07:31:49 |江苏| 显示全部楼层 |阅读模式
王志超 寇开昌 张冬娜 晁敏 吴广磊 陈名华西北工业大学理学院应用化学系,陕西西安710072
摘 要:采用铝酸酯偶联剂(DL-411-A)对实心玻璃微珠(SGM)进行了表面活化处理,分析了活化处理前后SGM表面的成分及形貌,对SGM的处理效果进行了评估。结果表明DL-411-A以化学键合的方式包覆在SGM表面,并提高了SGM颗粒与聚四氟乙烯(PTFE)基体间的相容性。经DL-411-A表面活化处理的SGM提高了PTFE基复合材料的拉伸强度、断裂伸长率及邵氏硬度。[著者文摘]
关键词:铝酸酯偶联剂 实心玻璃微珠 聚四氟乙烯 复合物
分类号: TQ316.63[著者标引]文献标识码:A文章编号:0253-4320(2010)07-0048-03栏目信息:科研与开发
Study on polytetrafiuoroethylene filled with aluminate treated solid glass microspheresWANG Zhi-chao, KOU Kai-chang, ZHANG Dong-na, CHAO Min, WU Guang-lei, CHEN Ming-hua Department of Applied Chemistry, School of Science, Northwestern Polytechnical University, Xi' an 710072, ChinaAbstract:The surface activation treatment with aluminate coupling agent (DL-411-A) of solid glass microsphere ( SGM ) is studied. The elements and surface morphology of SGM are analyzed before and after the treatment, the treating effects of DL-411-A on SGM are evaluated. The results show that the DL-411-A is bound onto the surface of SGM, and an organic layer is formed, and the interracial adhesion between polytetrailuoroethylene (PTFE) matrix and SGM particle is enhanced. Mechanical tests reveal that the tensile strengths, elongations at break and Shore hardnesses of PTFE/SGM composites are improved.[著者文摘]
Key words:aluminate coupling agent; solid glass microsphere; polytetrafluoroethylene; composite
铝酸酯处理实心玻璃微珠填充聚四氟乙烯复合材料的研究.pdf
263.7 KB, 下载次数: 1
GMT+8, 2026-8-7 14:41 , Processed in 0.019100 second(s), 9 queries , Redis On.
