查看: 2648|回复: 0
膨体聚四氟乙烯在鼻部整形中的应用
发表于 2012-6-28 22:04:57 |江苏| 显示全部楼层 |阅读模式
膨体聚四氟乙烯在鼻部整形中的应用
陈滔 陈志鹏 丁祖烈四川省攀枝花学院附属医院整形科,四川攀枝花617000
摘 要:目的:探讨鼻部整形中应用膨体聚四氟乙烯的手术方法及效果。方法:本组100例均采用"开放式"切口。根据鼻部具体情况,将膨体材料雕刻成所需形状,埋置于相应部位,构建鼻部假体支架,以此改善鼻部形态。结果:本组100例患者应用膨体行鼻部整形,术后随访1~4年,其中2例发生慢性排斥反应,1例受重力击打致假体外露,以致取出假体,其余97例形态自然,效果满意。结论:在鼻部整形中应用膨体可取得良好效果。[著者文摘]
关键词:膨体聚四氟乙烯(e-PTFE) 鼻整形
分类号: R622[著者标引]文献标识码:A文章编号:1008-6455(2010)04-0505-02栏目信息:眼耳鼻美容
相关文献:主题相关
The application of e-PTFE in nasal plasticCHEN Tao,CHEN Zhi-peng,DING Zu-lie Department of Plastic Surgery,Affiliated Hospital of Panzhihua College,Panzhihua 617000,Sichuan,ChinaAbstract:Objective Therapeutic methods and effects of utilizing e-PTFE in nasal plastic are discussed.Methods Open-incision method was used on 100 patients.According to different nasal situation,cut e-PTFE into needed shape,then put it at appropriate place,then construct the e-PTFE framework of nose to improve nasal contour.Results 100 patients were treated with aforementioned method.According to 1~4 years' follow-up,natural and satisfactory effects were achieved in 97 cases,except for two cases with chronic rejection and one case's implant uncovered after being hit.Conclusion The usage of e-PTFE in nasal plastic can acquire favorable effects.[著者文摘]
Key words:e-PTFE; nasal plastic
膨体聚四氟乙烯在鼻部整形中的应用.pdf
975.56 KB, 下载次数: 0
膨体聚四氟乙烯在鼻部整形中的应用
GMT+8, 2026-8-7 14:40 , Processed in 0.018912 second(s), 9 queries , Redis On.
