查看: 2422|回复: 0
Affinity Adsorption of Bilirubin on Cibacron Blue F3GA-modified Microporous P...
发表于 2012-6-28 22:37:48 |江苏| 显示全部楼层 |阅读模式
Affinity Adsorption of Bilirubin on Cibacron Blue F3GA-modified Microporous Polytetrafluoroethylene Capillary
JIN Gu YAO Jian-xiaDepartment of Chemistry, University of Science and Technology of China, Hefei 230026, P. R. China
摘 要:
关键词:F3GA 聚四氟乙烯 Cibacron 亲和吸附 胆红素 毛细管 微孔 甲基丙烯酸缩水甘油酯
分类号: TQ613 TQ325.4[机标]文献标识码:文章编号:1005-9040(2010)-02-323-08栏目信息:
Affinity Adsorption of Bilirubin on Cibacron Blue F3GA-modified Microporous Polytetrafluoroethylene CapillaryAbstract:Bilirubin removal from human plasma was obtained via an affinity microporous polytetrafluoroethylene(MPTFE) capillary. The new adsorbent comprised grafted glycidyl methacrylate(GMA) via radiation-induced polymerization as hydrophilic coating and reactive sites; ethylenediamine(EDA) as a spacer arm; Cibacron Blue F3GA(CB F3GA) as an affinity ligand; MPTFE capillary as the supporting matrix. The average density of CB F3GA attachment to MPTFE capillaries was found to be 136.5 μmol/g. The capacity of bilirubin adsorbed on affinity MPTFE capillaries is 76.1 mg bilirubin/g polymer(at 25℃). This new adsorbent has advantages over both membrane and traditional micro-column, and this system is stable and easy to operate. The results of blood tests suggest the CB F3GA affinity capillary has good blood compatibility.[著者文摘]
Key words:Bilirubin removal; Radiation grafting; Cibacron Blue F3GA; Polytetrafluoroethylene; Microporous capillary
Affinity Adsorption of Bilirubin on Cibacron Blue F3GA-modified Microporous Pol.pdf
516.47 KB, 下载次数: 0
Affinity Adsorption of Bilirubin on Cibacron Blue F3GA-modified Microporous Polytetrafluoroethylene ...
GMT+8, 2026-9-27 20:33 , Processed in 0.021832 second(s), 9 queries , Redis On.
