查看: 2568|回复: 0
含氟润滑油脂减摩性能及摩擦机制分析
发表于 2012-6-28 22:57:04 |江苏| 显示全部楼层 |阅读模式
含氟润滑油脂减摩性能及摩擦机制分析
杨广磊[1,2] 李庆忠[1] 倪自丰[1][1]江南大学机械工程学院,江苏无锡214122 [2]无锡技师学院,江苏无锡214153
摘 要:研究分析了聚四氟乙烯润滑油脂的减摩性能,得出了聚四氟乙烯润滑油脂摩擦因数与转速、温度和载荷变化关系。利用SEM和EDS对3种润滑剂摩擦膜进行形貌和能谱分析,认为聚四氟乙烯润滑油脂减摩是表面物理吸附膜和化学迁移膜共同作用的结果。[著者文摘]
关键词:润滑剂 聚四氟乙烯 扫描电子显微镜 X射线能谱
分类号: TH117.2[著者标引]文献标识码:A文章编号:0254-0150(2010)3-081-5栏目信息:试验研究
Research on Tribological Properties and Friction Mechanism about Fluorinated Lubricant GreaseYang Guanglei, Li Qingzhong Ni Zifeng1.School of Mechanical Engineering,Jiangnan University,Wuxi Jiangsu 214122,China;2.Wuxi Technician College,Wuxi Jiangsu 214153,ChinaAbstract:The friction properties of fluorinated lubricant grease were investigated,the friction properties which change with rotate speed,load and temperature were discussed.The wear scar morphologies of the surfaces lubricated by three kinds lubrication oils were analyzed by using scanning electron microscopy(SEM),and the element concentration were analyzed by X-ray energy spectrum(EDS).The theoretical analysis shows that because the combined effects of physical adsorption film and chemical migration film formed on friction surface,the fluorinated lubricant grease has good friction reducing properties.[著者文摘]
Key words:lubricants; polytetrafluoroethylene; SEM; EDS
含氟润滑油脂减摩性能及摩擦机制分析.pdf
398.88 KB, 下载次数: 0
含氟润滑油脂减摩性能及摩擦机制分析
GMT+8, 2026-8-7 14:40 , Processed in 0.059285 second(s), 10 queries , Redis On.
