查看: 2659|回复: 0
关于液压衬砌台车调整架的改进
发表于 2012-6-30 22:46:09 |江苏| 显示全部楼层 |阅读模式
关于液压衬砌台车调整架的改进
商艳 中铁十二局集团二公司,山西太原030032
摘 要:探讨了液压衬砌台车原调整架,结构及存在的问题,提出了调整架结构改进方案,并进行了理论分析,指出调整架改进后活动底座可以轻松移动,既省时又省力,使用效果良好。[著者文摘]
关键词:活动底座 平移架 液压调整缸 聚乙烯四氟板
分类号: TU755.2[著者标引]文献标识码:A文章编号:1009-6825(2010)07-0338-02栏目信息:机械与设备
On reform in adjusting bracket of hydraulic lining loop wheel machineSHANG YanSHANG YanAbstract:The paper explores the structure of the adjusting bracket of the hydraulic lining loop machine and its problems,points out the reform scheme for adjusting bracket structure,has the theoretic analysis,and points out the reformed travel base of the bracket can be removed easily,which can save time and strength,so its utility effect is better.[著者文摘]
Key words:travel base; horizontal travel bracket; hydraulic adjusting cylinder; polyethylene quadrinomal fluorine plate
关于液压衬砌台车调整架的改进.pdf
156.67 KB, 下载次数: 2
关于液压衬砌台车调整架的改进
GMT+8, 2026-8-7 14:39 , Processed in 0.442864 second(s), 9 queries , Redis On.
