查看: 7959|回复: 0
[原料树脂] PVDF D-1的溶胀特性
 火 [复制链接]
发表于 2008-11-21 20:52:13 |江苏| 显示全部楼层 |阅读模式
Maximum Solvent Uptake (wt%)
Dimethyl Carbonate
Battery Grades
30°C
40°C
50°C
60°C
KYNAR 741
14
15
17
24
KYNAR 301F
16
20
25
30
KYNAR FLEX 2801
60
148
PVDF D-1 LM
6.52
8.16
17.3
25.3
PVDF D-1 MM
8.31
8.41
23.6
29.1
PVDF D-1 HM
8.52
8.97
24.9
28.6
Diethyl Carbonate
Battery Grades
30°C
40°C
50°C
60°C
KYNAR 741
7
7
8
10
KYNAR 301F
9
10
11
13
KYNAR FLEX 2801
21
26
32
45
PVDF D-1 LM
0.57
0.73
2.66
2.86
PVDF D-1 MM
0.61
0.63
2.05
3.3
PVDF D-1 HM
0.77
0.86
1.95
3.86
Propylene Carbonate
Battery Grades
30°C
40°C
50°C
60°C
KYNAR 741
14
15
16
21
KYNAR 301F
17
20
25
30
KYNAR FLEX 2801
39
52
101
PVDF D-1 LM
2.17
2.8
4.88
9.93
PVDF D-1 MM
1.55
3.25
5.54
13.1
PVDF D-1 HM
1.81
3.91
6.82
13.8
Note:
1. Data of KYNAR series:
Obtained from the document of “KYNAR PVDF F0R LITHIUM BATTERIES”
2. PVDF D-1 series:
LM=low molecular weight, MM=Medium molecular weight, HM=High molecular weight
Rate of Solvent Uptake (g/s0.5, ×10-4)
Dimethyl Carbonate
Battery Grades
30°C
40°C
50°C
60°C
KYNAR 741
6
11
20
41
KYNAR 301F
2
5
10
30
KYNAR FLEX 2801
108
317
PVDF D-1 LM
2.7
9.7
12.5
18.0
PVDF D-1 MM
1.9
6.8
5.7
17.8
PVDF D-1 HM
1.3
3.2
6.0
14.3
Diethyl Carbonate
Battery Grades
30°C
40°C
50°C
60°C
KYNAR 741
0.65
1.6
2.9
5.8
KYNAR 301F
0.32
0.69
1.7
2.5
KYNAR FLEX 2801
11
21
49
140
PVDF D-1 LM
1.14
1.7
2.6
2.8
PVDF D-1 MM
0.72
0.9
1.3
1.53
PVDF D-1 HM
0.68
0.83
1.07
1.43
Propylene Carbonate
Battery Grades
30°C
40°C
50°C
60°C
KYNAR 741
1.4
2.8
5.8
12
KYNAR 301F
0.85
1.9
4.5
10.3
KYNAR FLEX 2801
16
33.8
136
790
PVDF D-1 LM
4.27
6.43
10.83
4.03
PVDF D-1 MM
1.07
1.53
4.17
5.6
PVDF D-1 HM
1.13
2.97
3.0
3.57
Note:
2. PVDF D-1 series:
Diffusion Coefficient of Solvents (cm2/s, ×10-9)
Dimethyl Carbonate
Battery Grades
30°C
40°C
50°C
60°C
KYNAR 741
1.8
4.5
15
35
KYNAR 301F
0.85
3.8
7.9
50.1
KYNAR FLEX 2801
34
69
PVDF D-1 LM
1.4
6
15.2
28.7
PVDF D-1 MM
1.9
7.7
20.3
36.9
PVDF D-1 HM
2.5
11.7
23.5
43.1
Diethyl Carbonate
Battery Grades
30°C
40°C
50°C
60°C
KYNAR 741
0.091
0.37
1.4
3.5
KYNAR 301F
0.056
0.21
1.1
1.8
KYNAR FLEX 2801
2.3
6.4
26
105
PVDF D-1 LM
0.013
0.3
2.1
3.2
PVDF D-1 MM
0.54
1.9
3.74
4.7
PVDF D-1 HM
0.64
1.77
4.24
5.9
Propylene Carbonate
Battery Grades
30°C
40°C
50°C
60°C
KYNAR 741
0.12
0.34
1.1
4.0
KYNAR 301F
0.14
0.46
1.5
5.2
KYNAR FLEX 2801
1.7
4.7
27
83
PVDF D-1 LM
0.18
0.25
1.22
3.6
PVDF D-1 MM
0.206
0.59
1.40
5.8
PVDF D-1 HM
0.21
0.63
1.74
6.4
Note:
2. PVDF D-1 series:
GMT+8, 2026-10-25 09:00 , Processed in 0.193057 second(s), 5 queries , Redis On.
