查看: 10672|回复: 0
[知识分享] 聚四氟乙烯英文性能指标
发表于 2008-11-30 22:02:49 |江苏| 显示全部楼层 |阅读模式
PTFE Detailed Properties
(Polytetrafluoroethylene)
The table below lists a generally accepted summary of properties that we believe to be reliable.   Please note that many of these resins are produced in several varieties and property characteristics may vary.  Therefore, determination of resin is dependent on the application and this table is only meant to serve as a general guideline.
Properties        ASTM or Unit        PTFE
MECHANICAL PROPERTIES
Specific Gravity        D792        2.18
Elongation %        D638        200~450
Tensile Strength (psi)        D638        2,000~4,500
Flexural Strength (psi)        D790        no break
Compressive Strength(psi)        D695        3,500(24MPa)
Tensile Elastic Modulus
(Young's Modulus) (psi)        D638        57,000
(psi)
Flexural Modulus
103MPa (103kgf/cm2)        D790        71,000~
85,000
        D790        0.5-0.6
(5.0-6.0)
FlexLife
(MIT cycles)        D2176        >1,000,000
Hardness Durometer
Shore D        D636        D50~65
Coefficient of Friction         on steel        0.02
Abrasion Resistance
1000 revs.        Taber        12
Impact Strength IZOD
73°F/23°C, notched ft/lbs/in        D256        3
THERMAL PROPERTIES
Melting Point        °C
(°F)        327
(621)
Upper Service
Temperature(20,000h)        °C
(°F)        260
(500)
Flame Rating**        UL 94        V-0
Thermal Conductivity
        BTU/hr/ft2/deg F in        1.7
        cal/sec/cm2,ºC/cm        6 x 10-4
Linear Coefficient of Thermal Expansion 10-5 °C        D696        >11.6
Heat of Fusion        BTU/LB        29-37
Heat of Combustion        BTU/LB        2200
Low Temperature Embrittlement        °C
(°F)        -268
(-450)
ELECTRICAL PROPERTIES
Dielectric Constant        D150/103Hz        2.1
        D150/106Hz        2.1
Dielectric Strength
10 mil film        D149        >1400
Volume Resistivity ohm-cm        D257        >1018
Surface Resistivity
ohm/sq.        D257        >1017
GENERAL PROPERTIES
Chemical/Solvent
Resistance        D543        Excellent
Water Absorption, 24h        %        <0.01
Deformation Under Load        *D621/100°C        5.0
        **D621/25°C        7.0
Refractive Index                 1.35
Limiting Oxygen Index        >95        >95
*6.8 MPa (986 psi),24h
**13.7 MPa (1987 psi),24h
物理性能:聚四氟乙烯塑料表面光滑,蜡状,极梳水。一般为乳白色不透明。但淬火制品具有一定的透明性。平均密度为2.2。
力学性能:抗拉强度20.0~30.0MPa,断裂伸长率300%~400%。弹性模量400 Mpa。表面硬度大约为55-70HS。PTFE之间的摩擦系数大约为0.1-0.2。
化学性能:能耐绝大部分强腐蚀性物质,至今尚无一种能在300℃以下溶解它的溶剂。耐候性强。可存放10年以上。
GMT+8, 2026-10-25 09:01 , Processed in 0.109863 second(s), 5 queries , Redis On.
