查看: 4230|回复: 0
塑料-模塑材料:聚四氟乙烯(PTFE)模塑材料分类和标记
发表于 2008-12-6 10:16:53 |江苏| 显示全部楼层 |阅读模式
塑料-模塑材料:聚四氟乙烯(PTFE)模塑材料分类和标记DIN 16782-1-1991,此标准为英文版
Kunststoff-Formmassen: Polytetrafluorethylen (PTFE)-Formmassen; Einteilung und Bezeichnung
In keeping with current practice in standards published by the International Organization for Standardization @O), a comma
has been used throughout as the decimal marker.
1 Scope and field of application
This standard establishes a system of classification and designation for PTFE moulding materials'), based on their chemical structure, polymerization or emulsion method and
main application, any essential additives and filler type and content, and their designatory properties.
Since the designation system does not cover all properties of a material, moulding materials assigned the same designation according to this standard are not necessarily interchangeable.
Additional properties will often be required for a particular application or method of processing, and these shall be subject to agreement between the customer and supplier.
They shall be determined using the test methods specified in DIN 16782 Part 2, if these are applicable, and may be included in the designation system (clause 3).
DIN_16782-1-1991_塑料-模塑材料.聚四氟乙烯(PTFE)模塑材料.分类和标记.pdf
217.57 KB, 下载次数: 45
GMT+8, 2026-10-26 08:36 , Processed in 0.083881 second(s), 8 queries , Redis On.
