查看: 2794|回复: 0
CaF2填充PTFE三层复合材料摩擦学性能研究
发表于 2012-10-13 13:30:25 |江苏| 显示全部楼层 |阅读模式
Study on the Tribological Properties of CaF2 Filled PTFE Three-layer Composite Materials
作  者:吴良奎[1] 焦明华[2]
WU Liang-kui, JIAO Ming-hua  ( l.College of Forest Utilization, Anhui Agricultural University, Hefei 230036, China; 2. Hefei University  of Technology, Hefei 230009, China)
机构地区:[1]安徽农业大学林学与园林学院,合肥230036 [2]合肥工业大学,合肥230009
出  处:《机械工程师》 2008年第8期 109-110页,共2页
Mechanical Engineer
摘  要:制备了氟化钙CaF2填充PTFE三层复合材料,并在端面摩擦磨损试验机上对其进行了常温干摩擦及预浸油摩擦实验,探讨了CaF2含量对材料摩擦磨损性能及磨损机理的影响。结果表明,随着CaF2含量的增加,材料的摩擦因数逐渐增大,但添加少量CaF2时材料的耐磨损性能明显提高,说明少量CaF2的加入有利于改善材料的综合摩擦磨损性能。
The friction and wear behavior of CaF2 filled PTFE three-layer composite was tested under the End Friction Testing Machine, and the influence of CaF2 content was studied. The results showed that the coefficient of friction of the composite increased with the increase of CaF2 content, meanwhile the wear of the composite decreased obviously when filled with few CaF2, which means that CaF2 can improve the tribologieal properties of the composites.
关 键 词:PTFE 氟化钙 摩擦性能 磨损性能
PTFE CaF2 friction behavior wear behavior
分 类 号:TH117.1 [工业技术 > 机械、仪表工业 > 机械学(机械设计基础理论) > 机械摩擦、磨损与润滑]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (5篇)[1]廖曼青 等.SF-1三层复合自润滑材料的摩擦特性及应用[J].塑料,1992(2):44-47.
[2]Martyak N M,Wetterer S, et al. Structure of electroless nickel coatings,Plating and Surface Fishing[J], 1993,80(6) :60-62.
[3]冯大鹏 刘近朱.耐高温无机固体润滑剂的发展[J].润滑与密封,:.
[4]温诗铸 黄平.摩擦学原理[M].北京:清华大学出版社,2002..
[5]MengJunhu(孟军虎)etal.[J].稀有金属材料与工程,2004,33(7):714.
CaF_2填充PTFE三层复合材料摩擦学性能研究.pdf
827.06 KB, 下载次数: 0
GMT+8, 2026-9-27 05:01 , Processed in 0.529989 second(s), 9 queries , Redis On.
