查看: 2761|回复: 0
Ekonol填充PTFE三层复合材料摩擦学性能研究
发表于 2012-10-13 13:32:56 |江苏| 显示全部楼层 |阅读模式
Study on the Tribological Properties of Ekonol Filled PTFE  Three-layer Composite Materials
作  者:吴良奎[1] 焦明华[2]
Wu Liangkui Jiao Minghua ( 1. College of Forest Utilization Anhui Agricultural University, Hefei Anhui 230036, China ;  2. Hefei University of Technology, Hefei Anhui 230009, China)
机构地区:[1]安徽农业大学林学与园林学院,安徽合肥230036 [2]合肥工业大学,安徽合肥230009
出  处:《润滑与密封》 CAS CSCD 2008年第33卷第10期 49-51页,共3页
Lubrication Engineering
基  金:基金项目:安徽农业大学木材科学与技术科技创新团队资助.
摘  要:在端面摩擦磨损试验机上对Ekonol填充PTFE三层复合材料试样进行了常温干摩擦实验,探讨了Ekonol含量对材料摩擦磨损性能及磨损机制的影响。结果表明,随着Ekonol含量的增加,材料的摩擦因数逐渐增大,但总体上比较小(〈0.14),表现出了较好的摩擦性能,同时材料的耐磨损性能随Ekonol含量的增加而增大,说明Ekonol的加入有利于改善材料的摩擦学性能。
The friction and wear behavior of Ekonol filled PTFE three-layer composite was tested under the End Friction Testing Machine, and the influence of Ekonol content was studied. The results show that the coefficient of friction of the composite increases with the increase of Ekonol content, but the coefficient of friction is small( 〈 0. 14), which shows well friction behavior. The wear of the composite decreases obviously, which means that Ekonol can improve the wear resistance of the composites.
关 键 词:Ekonol PTFE 摩擦性能 磨损性能
Ekonol PTFE friction behavior wear behavior
分 类 号:TH117.1 [工业技术 > 机械、仪表工业 > 机械学(机械设计基础理论) > 机械摩擦、磨损与润滑]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (7篇)[1]A K Pogosian. Wear Mechanism and Transfer Film of Polymers [ C ]. The 4th European Tribology Congress, 1985.
[2]王家序 陈战 等.聚四氟乙烯复合材料的摩擦磨损性能研究[J].农业机械学报,:.
[3]曾竞成 罗青 唐羽章.复合材料理化性能[M].长沙:国防科技大学出版社,1998..
[4]罗虹 张志军.几种不同硬度材料的滑动磨粒磨损特征[J].摩擦学学报,:.
[5]Talat Tevrnz. Tribological behaviours of carbon filled polytetrafluoroethylene ( PTFE ) dry journal bearings [ J ]. Wear, 1998, 221:61-68.
[6]K Tanaka, S Kawakami. Effects of various fillers on the friction and wear of polytetrafluoroethylene - based composites [J]. Wear, 1982, 79:221-234.
[7]蔡立芳 黄承亚 易荣.Ekonol/石墨/MoS2填料对PTFE力学和摩擦磨损性能的影响[J].润滑与密封,2006(2):83-86.
Ekonol填充PTFE三层复合材料摩擦学性能研究.pdf
428.71 KB, 下载次数: 0
GMT+8, 2026-10-5 13:08 , Processed in 0.125645 second(s), 9 queries , Redis On.
