查看: 3101|回复: 0
汉麻粉体/PVDF共混膜的制备、表征及对Cu2+吸附性能研究
发表于 2012-10-13 14:54:59 |江苏| 显示全部楼层 |阅读模式
Preparation, Characterization of Hemp Powder/PVDF Blending Membrane  and Its Adsorption Characteristic of Cu2+
作  者:吴艳玲 钟智丽
WU Yan-ling, ZHONG Zhi-li (School of Textiles,Tianjin Polytechnic University, Tianjin 300160, China)
机构地区:天津工业大学纺织学部,天津300160
出  处:《城市环境与城市生态》 CAS CSCD 2012年第25卷第3期 43-46页,共4页
Urban Environment & Urban Ecology
摘  要:采用浸没沉淀法,制备了汉麻粉体/PVDF混合平板膜,分别采用扫描电镜、孔隙率、机械性能测试对膜结构和性能进行表征,探究汉麻粉体对膜结构性能的影响。结果表明:膜结构为指状多孔膜,随着汉麻粉体含量的增加,从断面结构可见,脆性增加,断面整齐,指状孔明显,膜的孔径有先增大、后减小的趋势;表征结果表明膜的孔隙率有提高的趋势;承受最大载荷增加,断裂伸长率下降。汉麻粉体膜制备完成后,采用静态吸附法进行吸附试验,分别探讨了温度、粉体含量、铜离子的初始浓度对吸附效果的影响。结果表明:汉麻粉体膜对铜离子的吸附,当温度为25℃时,吸附量与吸附率最佳;随着粉体含量的增加,吸附量与吸附率先减小、后增大的趋势。初始浓度的影响较为显著,随着初始浓度的增加,吸附量与吸附率也随之增加。
A hemp powder/PVDF blending flat membrane was prepared with the method of immersion precipitation. Cu2+ adsorption capacity of the hemp/PVDF blending membrane were characterized with SEM morphology, porosity, mechanic performance to investigate the structure and performance of the membrane. The results indicated that the blending membrane was finger-shaped porous membrane. With the increase of hemp powder content, membrane brittleness increased, cross section was tidiness and finger-shaped hole was obvious. Membrane hole had the trend of first increases and then decreases. The characterization results indicated that membrane porosity improved compared with not adding hemp powder. Maximum load value and Elongation at break were variable. After hemp-PVDF blending membrane was prepared, static adsorption method was selected to carry out the adsorption experiment. Hemp powder content, temperature and initial concentration of Cu2+ were studied. The obtained results showed that the sorption capacity for Cu2+ was the maximum when the temperature was 25℃. The sorption capacity and adsorption rate reduced firstly, then improved with the increase of hemp powder content. The initial concentration of the solutions was significant to adsorption. Increasing the initial concentration of the solutions resulted in increased sorption capacity.
关 键 词:汉麻粉体 膜吸附 共混膜 Cu2+ PVDF
hemp powder membrane adsorption blending membrane Cu2+ PVDF
分 类 号:X703.1 [环境科学、安全科学 > 废物处理与综合利用 > 一般性问题 > 废水的处理与利用]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (10篇)[1]张建春 张华 来侃 等.汉麻纤维的结构与性能[M].北京:化学工业出版社,2009..
[2]张志辉 刘晓伟 宋来洲.DTPA-MA/PVDF共混膜对Ni2+吸附性能的研究[J].唐山师范学院学报,2010,32(2):16-20.
[3]宋来洲 张尊举 郑秋艳.聚偏氟乙烯共混改性膜对Cu^2+吸附性能的研究[J].环境科学,2007,28(11):2500-2506.
[4]包艳辉 朱宝库 陈炜 徐又一 徐志康.聚偏氟乙烯微孔膜的亲水化改性及功能化研究进展[J].功能高分子学报,2003,16(2):269-274.
[5]乔玉新 宋来洲.聚偏氟乙烯共混改性膜对Zn(Ⅱ)吸附性能的研究[J].唐山师范学院学报,2008,30(5):27-32.
[6]曾琳 王继斌 宋来洲.聚丙烯酸聚偏氟乙烯共混膜对Cu2+吸附特性的研究[J].环境科学与管理,2008,33(3):114-119.
[7]Yu- Ming Zhenga, Shuai- Wen Zoua, K. G. Nadeeshani Nanay- akkarsa, et al. Adsorptive Removal of Arsenic from Aqueous Solution by A PVDF/zirconia Blend Flat Sheet Membrane [ J ]. Journal of Membrane Science,2011,3 (374) : 1-11.
[8]李香莉 肖凯军 郭祀远.PVDF-A1203杂化膜的制备与性能表征[J].华南理工大学学报:自然科学版,2010,7(38):112-116.
[9]邱菊生 钟智丽.[D].天津:天津工业大学,2010:1-68.
[10]何炳林.黄文强离子交换与吸附树脂[M].上海:上海科技教育出版社,1995.406.
汉麻粉体/PVDF共混膜的制备、表征及对Cu2+吸附性能研究.pdf
283.37 KB, 下载次数: 0
GMT+8, 2026-11-2 10:09 , Processed in 0.072643 second(s), 8 queries , Redis On.
