查看: 6845|回复: 0
[知识分享] 焊接用语
发表于 2008-12-25 20:55:28 |江苏| 显示全部楼层 |阅读模式
acetylene 乙炔 ampere 电流安培
angle welding 角焊 arc 电弧
argon arc welding 氩弧焊接 bare electrode 光熔接条
butt welding 对接焊接 camber 电弧弯曲
cascade 阶叠熔接法 clad weld 被覆熔接
crator 焊疤 excess metal 多余金属
filler rod 焊条 fillet weld 填角焊接
gas shield 气体遮蔽 groove welding 起槽熔接
hand face shield 手握面罩 hard facing 硬表面堆焊
jig welding 工模焊接 laser beam welding 雷射光焊接
metal electrode insert gas welding MIG熔接 nugget 点焊熔核
overlaying 堆焊 peening of welding 珠击熔接法
plug welding 塞孔熔接 positioned welding 正向熔接
pressure welding 压焊 propane gas cutting 丙烷气切割
pure nickel electrode 纯镍熔接条 reinforcement of weld 加强焊接
resist 抗蚀护膜 root running 背面熔接
seam 焊缝 seaming 接合
seam welding 流缝熔接 series seam welding 串联缝熔接
skip welding process 跳焊法 spark 火花
spot welding 点焊接 stitch welding 针角焊接
stud arc welding 电弧焊接 under laying 下部焊层
void 焊接空隙 weld flow mark 焊接流痕
weld flush 焊缝凸起 weld line 焊接纹
weld mark 焊接痕 weld penetration 熔接透入
weld zone 焊接区 welding 焊接
welding bead 焊接泡 welding direction 焊接方向
welding distortion 焊接变形 welding flux 焊剂
welding ground 电熔接地 welding interval 焊接周期
welding stress 熔接应变 welding torch 熔接气炬
GMT+8, 2026-10-25 09:01 , Processed in 0.068718 second(s), 5 queries , Redis On.
