查看: 3621|回复: 0
温度对PTFE膜材料力学性能的影响
发表于 2012-12-11 20:56:13 |江苏| 显示全部楼层 |阅读模式
温度对PTFE膜材料力学性能的影响
Effects of Temperature on Mechanical Properties of PTFE Coated Fabrics
作  者:张营营[1,2] 张其林[2] 周传志[2]
ZHANG Ying-ying , ZHANG Qi-lin , ZHOUChuan-zhi (1. Jiangsu Key I.aboratory of Environmental Impact and Structural Sa{ety in Engineering, China University of Mining ~-  Technology, Xuzhou 221116, China~ 2. College o{ Civil Engineering, Tongji University, Shanghai 200092, China)
机构地区:[1]中国矿业大学江苏省土木工程环境灾变与结构可靠性重点实验室,江苏徐州221116 [2]同济大学土木工程学院,上海200092
出  处:《建筑材料学报》 EI CAS CSCD 2012年第15卷第4期 478-483页,共6页
Journal of Building Materials
基  金:基金项目:国家自然科学基金资助项目(90815003);国家科技支撑计划项目世博科技专项(2009BAK43806);光华同济土木学院基金资助项目
摘  要:对聚四氟乙烯(PTFE)膜材进行了9种温度(-20,~10,0,10,23,40,50,60,70℃)下的单轴单调和循环拉伸试验,得到了膜材力学参数的变化规律.结果表明:随着温度的增加,PTFE膜材的抗拉强度逐渐减小,而断裂延伸率和弹性模量逐渐增大;随着循环次数的增加,PTFE膜材滞回曲线趋于稳定,残余应变趋于常数.在试验研究的基础上,提出了PTFE膜材强度的温度影响系数,为PTFE膜材强度设计分项系数的取值提供了依据.
Uniaxial tensile tests on poly tetra fluoro ethylene(PTFE) coated fabric were carried out under monotonic and cyclic loading, in which nine environment temperatures were considered including --20, --10, 0, 10, 23, 40, 50, 60 and 70 ℃. The variation trends of membrane mechanical properties were ob- tained. The test results show that the membrane tensile strength will decrease, and the breaking strain and the elastic modulus will increase with the increase of the environment temperatures. The hysteresis curves of the membrane material will tend to stable and the unloaded residual strain will tend to a constant with the increase of the loading cycles. On the basis of the test results the temperature influence factors of the membrane strength are proposed, which can be taken in the study of the partial coefficients of membrane strength design value.
关 键 词:聚四氟乙烯(PTFE)膜材 温度 循环荷载 高温折减系数
poly tetra fluoro ethylene(PTFE) coated fabric temperature cyclic loading high temperature reduction factor
分 类 号: TU502.6 [工业技术 > 建筑科学 > 建筑材料 > 一般性问题 > 材料性能及试验] TB332 [工业技术 > 一般工业技术 > 工程材料学 > 复合材料]
相似文献与本文研究主题相似的文献,反映同类研究现状。 (10篇)[1]高温与持续荷载的复合作用对防水卷材拉伸性能的影响
[2]混凝土双轴拉压动态强度及破坏准则试验
[3]考虑封闭效应的钢管混凝土的轴压承载力研究
[4]杠杆卧拉式徐变装置测定混凝土早期徐变试验研究
[5]关于机制砂混凝土性能的试验研究
[6]温度对PTFE膜材料力学性能的影响
[7]浅谈高性能混凝土在工程中的运用
[8]CFRP筋夹板式锚具锚固性能试验研究
[9]木梁抗弯性能试验研究
[10]钢-再生混凝土组合结构力学性能研究综述
温度对PTFE膜材料力学性能的影响.pdf
362.28 KB, 下载次数: 0
温度对PTFE膜材料力学性能的影响
GMT+8, 2026-7-15 00:52 , Processed in 0.027521 second(s), 10 queries , Redis On.
