查看: 2708|回复: 0
SiO2含量对PTFE/SiO2复合材料性能的影响
发表于 2012-12-11 21:14:38 |江苏| 显示全部楼层 |阅读模式
Effects of SiO2 Content on the Properties of PTFE/SiO2 Composites
作  者:庞翔 袁颖 肖勇 童启铭 李攀敏 邓新峰
PANG Xiang, YUAN Ying, XIAO Yong, TONG Qiming, LI Panmin, DENG Xinfeng (State Key Lab. of Electronic Thin Films and Integrated Devices, University of Electronic Science and Technology of China,  Chengdu 610054, China)
机构地区:电子科技大学电子薄膜与集成器件国家重点实验室,四川成都610054
出  处:《压电与声光》 CSCD 2012年第34卷第4期 577-580页,共4页
Piezoelectrics & Acoustooptics
摘  要:采用类似于粉末冶金工艺,制备了无定形SiO2填充聚四氟乙烯(PTFE)复合材料,并对其进行了热、介电性能测试和SEM分析表征。系统研究了(1-x)PTFE—xSiO2(x为质量比)复合介质材料中,不同x值(x=0.35,0.40,0.45,0.50,0.55)对材料结构和性能的影响。结果表明,复合材料的密度随着SiO2含量的增加而减少,吸水率、热膨胀系数、介电常数和介电损耗随着SiO2含量的增加而增加。当SiO2质量分数为50%时,PTFE能很好地在SiO2表面形成一层包覆层,此时复合材料具有合适的热膨胀系数(17u ℃-1)、介电常数(2.74)和低介电损耗(0.0024)。
The amorphous SiO2 filled PTFE composite materials were prepared by using the technology similar to the powder metallurgy. The thermal and dielectric properties of the composites were measured. Also, the microstructure evolution of the composites was characterized by the scanning electron microscopy (SEM). The effects of the different x value (x is the mass ratio, x = 0. 35,0.40,0.45,0. 50,0. 55) on the microstructure and dielectric properties of (1-x) PTFE-xSiO2 composite dielectric material were investigated. It was found that the density of the composite decreased as the content of SiO2 increased. On the other hand,the water absorption,thermal expansion coefficient, dielectric constant and dielectric loss were increased with the SiO2 content increasing. When the content of SiO2 reached 50 %, PTFE could be well coated by the SiO2 layers, and the composites showed suitable thermal expansion coefficient (17 u ℃ -1) ,dielectric constant (2.74) and low dielectric loss (0. 002 4).
关 键 词:复合材料 SiO2 聚四氟乙烯 热膨胀系数 介电性能
composite material SiO2 polyfluortetraethylene (PTFE) thermal expansion coefficient dielectric property
分 类 号: TQ327.9 [工业技术 > 化学工业 > 合成树脂与塑料工业 > 增强塑料、填充塑料]
相似文献与本文研究主题相似的文献,反映同类研究现状。 (10篇)[1]TiO_2含量对PTFE/TiO_2微波介质复合材料性能的影响
[2]Hybrid Electrochromic Multilayer Films Based on Fe(II)-Metalloviologens and TiO_2 Nanoparticles
[3]蒙脱土/环氧树脂杂化胶粘涂层耐蚀性能研究
[4]塑木复合材料加工工艺要点
[5]中国合成橡胶工业协会2012年丁二烯/异戊二烯、丁二烯橡胶/苯乙烯-丁二烯-苯乙烯嵌段共聚物(SBS)生产技术交流研讨会在乌鲁木齐召开
[6]高性能天然纤维带和展开丝束织物
[7]PBT的湿热老化性能研究(一)
[8]蔗渣纤维增强PP复合材料
[9]无卤阻燃增韧尼龙612/EOPE—g—MA/MPP复合材料的制备
[10]聚丙烯基纳米TiO2的表面改性
SiO2含量对PTFE/SiO2复合材料性能的影响.pdf
532.83 KB, 下载次数: 0
GMT+8, 2026-8-15 13:59 , Processed in 0.024351 second(s), 9 queries , Redis On.
