查看: 2793|回复: 0
聚四氟乙烯型印刷线路板的热解实验
发表于 2012-12-30 15:14:40 |江苏| 显示全部楼层 |阅读模式
聚四氟乙烯型印刷线路板的热解实验
Experimental research on pyrolysis of polytetrafluoroethylene-printed circuit boards
作  者:郭晓娟 张于峰 魏莉莉 马洪亭
Guo Xiaojuan ,Zhang Yufeng ,Wei Lili Ma Hongting (School of Environmental Science and Engineering, Tianjing University, Tianjin 300072, China)
机构地区:天津大学环境科学与工程学院,天津300072
出  处:《华中科技大学学报:自然科学版》 EI CAS CSCD 2008年第36卷第10期 121-124页,共4页
JOURNAL OF HUAZHONG UNIVERSITY OF SCIENCE AND TECHNOLOGY.NATURE SCIENCE
基  金:国家自然科学基金资助项目(50378062);教育部科学技术研究重点项日(108030).
摘  要:利用热重(TG)法进行了聚四氟乙烯(PTFE)型印刷线路板不同升温速率的热解特性实验研究,建立了表观热解反应动力学模型.利用固定床热解试验装置进行了PTFE线路板热解实验,利用气-质联用(GC—MS)和扫描电镜(SEM)分别检测了热解气体和固体产物.结果表明:a.所建热解模型与实验数据符合较好,求得动力学三参数分别为活化能223.606kJ/mol,反应级数0,指前因子1.529×10^13min^-1;b.热解气体产物主要为八氟环丁烷.手动剥离即可实现金属和玻璃纤维等组分的分离富集.富集的金属片主要为铜片及其镀层上含有少量的金、镍等贵重金属;富集的玻璃纤维中含有大量的碳,还有一定量的O,F,Al,Si,Ca,Ti等元素.
Pyrolysis characteristics of waste polytetrafluoroethylene(PTFE)-printed circuit boards were investigated under different heating rates with thermogravimetry (TG). A kinetic model for expressing the pyrolysis reaction was established. A fixed-bed experimental apparatus was used to pyro lyze the printed circuit boards and the products were analysised by using gas chromatograph and mass spectrometer (GC-MS) and scanning electronic microscopy (SEM). The results show: a. the kinetics model was in good agreement with the experimental ones at four heating rates, the kinetics parameters of polytetrafluoroethylene-type printed circuit boards was zero-order for reaction order, 223. 606 kJ/mol for the activation energy, 1. 529× 1013 min ^-1 for pre-exponential factor; b. octafluorocyclobutane was the main content of the pyrolysis gas. Glass fiber and metallic fractions were easily seperated and accumulated. The accumulated metals were mainly copper strip and a bit golden and nickel were plated on the strips. The enriched glassfibre consists of amount of carbon and significant concentra- tions of O,F,AI,Si,Ca,Ti.
关 键 词:印刷线路板 热解实验 聚四氟乙烯 反应动力学模型 分离富集 玻璃纤维 气-质联用 八氟环丁烷
printed circuit board polytetrafluoroethylene(PTFE) solid waste pyrolysis kineticmodel analysis of the product
分 类 号: TQ325.4 [工业技术 > 化学工业 > 合成树脂与塑料工业 > 聚合类树脂及塑料] TN41 [工业技术 > 无线电电子学、电信技术 > 微电子学、集成电路(IC)]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (10篇)[1]杨玉芬 盖国胜 徐盛明 陈清如.废印刷线路板回收利用的现状与存在的问题[J].环境污染与防治,2004,26(3):193-196.
[2]Hall W J, Williams P T. Separation and recovery of materials from scrap printed circuit boards[J]. Resources, Conservation and Recycling, 2007, 51 (3): 691-709.
[3]Blazso M, Czegeny Z, Csoma C. Pyrolysis and debromination of flame retarded polymers of electronic scrap studied by analytical pyrolylsis[J]. Journal of Analytical and Applied Pyrolysis, 2002, 64(2): 249- 261.
[4]Hornung A, Balabanovich A I, Donner S, et al. Detoxification of brominated pyrolysis oils[J]. Analytical and Applied Pyrolysis, 2003, 70(2):723-733.
[5]孙路石.[D].武汉:华中科技大学,2004.
[6]杨维生.多层微带线路板制造技术研究[J].电子工艺技术,2005,26(5):267-272.
[7]胡荣祖 史启祯.热分析动力学[M].北京:科学出版社,2001..
[8]Morisaki S. Simultaneous thermogravimetry-mass spectrometry and pyrolysis-gas chromatography of fluorocarbon polymers [J ]. Thermochimica Acta,1978, 25(2):171-183.
[9]Simon C M, Kaminsky W. Chemical recycling of polytetrafluoroethylene by pyrolysis[J]. Polymer Degradation and Stability, 1998, 62(1): 1-7.
[10]Egbert Meissner, Agnieszka Wroblewska, Eugeniusz Milchert. Technological parameters of pyrolysis of waste polytetrafluoroethylene[J]. Polymer Degradation and Stability, 2004, 83(1): 163-172.
相似文献与本文研究主题相似的文献,反映同类研究现状。 (10篇)[1]苏威法国PVDF装置扩能50%
[2]某型飞机主泵出Ф14mm高压聚四氟乙烯软管组件的设计改进(下)
[3]金属/PES复合自润滑材料的制备及摩擦学性能研究
[4]硫酸钙晶须改性聚四氟乙烯的摩擦磨损性能研究
[5]碳纤维改性聚四氟乙烯密封环的研制
[6]杜邦推出耐300℃线缆氟塑料
[7]某型飞机主泵出口Ф14mm高压聚四氟乙烯软管组件的设计改进(上)
[8]Kynar~氟聚合物在聚烯烃薄膜加工中的应用——提高产量,减少停机时间
[9]聚偏氟乙烯/聚醚酰亚胺共混溶液的流变性能研究
[10]上海金由等膜裂法高性能聚四氟乙烯纤维技术实现产业化
聚四氟乙烯型印刷线路板的热解实验.pdf
248.77 KB, 下载次数: 0
聚四氟乙烯型印刷线路板的热解实验
GMT+8, 2026-7-15 00:29 , Processed in 0.046738 second(s), 8 queries , Redis On.
