查看: 3088|回复: 0
预辐射接枝四氟乙烯-乙烯共聚物湿敏膜的制备及特性研究
发表于 2012-12-30 15:16:45 |江苏| 显示全部楼层 |阅读模式
Preparation and Properties of the ETFE Humidity Sensing Films  by Pre-irradiation Grafting Method
作  者:付群 王德庆 焦正 吴明红
FU Qun, WANG De-Qing, JIAO Zheng, WU Ming-Hong (Shanghai Applied Radiation Institute, School of Environmental and Chemical Engineering, Shanghai University,  Shanghai 201800, China)
机构地区:上海大学环境与化学工程学院,上海射线应用研究所,上海201800
出  处:《高等学校化学学报》 SCI CAS CSCD 2008年第29卷第10期 2111-2114页,共4页
Chemical Research In Chinese Universities
基  金:国家自然科学基金(批准号:50578090)、上海市曙光计划(批准号:07SG46)和新世纪优秀人才计划(批准号:NCET-05-0434)资助.
摘  要:利用2 MeV电子加速器,在常温下采用预辐照引发接枝的方法,在四氟乙烯-乙烯共聚物(ETFE)上接枝丙烯酸(AA)和对苯乙烯磺酸钠(SSS),制备了一种含羧酸基团和磺酸基团的接枝膜.傅里叶变换红外光谱(FTIR)分析结果证明了磺酸基团和羧酸基团的成功引入,并对接枝膜的热力学和化学特性进行了研究.结果表明,随着接枝率的增加,接枝膜的结晶度逐渐降低,接触角逐渐减小,接枝膜的亲水性逐渐增强.利用制备的接枝膜构建了电阻型湿度传感器,并测定了传感器的电学特性.在相对湿度(RH)从5%变化到98%时,传感器电阻线性变化范围接近4个数量级,具有响应速度快(吸附〈1 min,解吸〈2 min),湿滞小(〈2%RH)的特点.
Acrylic acid (AA) and sodium styrene sulfonate (SSS) were grafted onto poly( ethylene-co-tetrafluoroethylene) (ETFE) film by pre-irradiation technique using electronic beam from a 2 MeV accelerator at room temperature. A humidity sensing film with strong acid and weak acid groups was prepared. Infrared spectros- copy analysis of the grafted film confirmed the existence of sulfonate and carboxylic acid groups in the grafted film. Thermal and chemical properties of the grafted films were investigated. The crystallinity and static contact angle of the grafted films decrease, meanwhile the hydrophilicity of the grafted films increases with increasing grafting yield. A resistive-type humidity sensor was prepared using the grafted film, and its electrical response to humidity was examined. The resistive of the sensor changes linearly by 4 orders of magnitude over almost whole humidity range (5 % -98 % RH). Furthermore, the sensor exhibits a quick response ( absorption : less than 1 min; desorption: less than 2 min) and small hysteresis(less than 2% RH).
关 键 词:预辐照接枝 丙烯酸 对苯乙烯磺酸钠 四氟乙烯-乙烯共聚物
Pre-irradiation grafting Acrylic acid Sodium styrene sulfonate Poly( ethylene-co-tetrafluoroethylene)
分 类 号: O631.34 [数理科学和化学 > 化学 > 高分子化学(高聚物) > 高分子物理和高分子物理化学 > 高聚物的化学性质]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (13篇)[1]刘崇进 沈家瑞.高分子湿度传感器的发展概况和发展方向[J].仪表技术与传感器,:.
[2]Trupti M. , Mulla I. S. , Sainkar S. R. , et al.. Sensor Actuat B Chem. [J], 2002, 81(2/3) :141--151.
[3]金兴良 荆淼 赵英等.温度对Nafion-结晶紫光纤湿度传感器性能的影响[J].高等学校化学学报,(5)26:844-845.
[4]Gong Myoung-Seon, Park Jae-Seok, Lee Myong-Hoon, et al.. Sensor Actuat B Chem. [ J ] , 2002, 86 ( 1 ) : 160--167.
[5]Adhikari B. , Majumdar S.. Progress in Polymer Science[ J] , 2004, 29:699--766.
[6]Sakai Y. , Matsuguchi M. , Yonesato N. , et al.. Electrochim. Acta[J] , 2001, 46:1509--1514.
[7]XINZhi—Rong(辛志荣) ZHAOYu—Xia(赵郁霞) HOUWan—Guo(侯万国) etal.[J].等学校化学学报,2007,28(10):1990-1994.
[8]GengW. C., WangR., LiX. T., etal.. SensorAetuat B Chem.[J],2007, 127(2): 323--329.
[9]Huang X. F. , Sheng D. R. , Cen K. F. , et al.. Sensor Actuat B Chem. [J], 2007, 127(2) : 518--524.
[10]Su Pi-Guey, Sun Yi-Lu, Wang Chao-Shen, et al.. Sensor Actuat B Chem. [J], 2006, 119(2) : 483---489.
[11]LIZhen(李珍) WuMing—Hong(吴明红) JIAOZheng(焦正) etal.[J].高校化学工程学报,2007,21(3):500-504.
[12]Gupta B. , Anjum N.. J. Appl. Polym. Sci. [J], 2001, 82:2629--2635.
[13]Zevin L. , Messalem R.. Polymer[ J], 1982, 23:601--605.
预辐射接枝四氟乙烯-乙烯共聚物湿敏膜的制备及特性研究.pdf
275.93 KB, 下载次数: 0
GMT+8, 2026-7-15 00:28 , Processed in 0.022084 second(s), 10 queries , Redis On.
