查看: 4230|回复: 0
纳米SiC改性PTFE复合材料的力学与摩擦磨损性能
发表于 2012-12-30 15:18:36 |江苏| 显示全部楼层 |阅读模式
Frictional and Mechanical Properties of PTFE  Composites Filled with Nano-SiC
作  者:路琴 张静 何春霞
LU Qin, ZHANG Jing, HE Chun-xia (College of Engineering, Nanjing Agricultural University, Nanjing 210031, China)
机构地区:南京农业大学工学院,江苏南京210031
出  处:《材料科学与工程学报》 CAS CSCD 2008年第26卷第5期 743-745页,782页,共4页
Journal of Materials Science and Engineering
基  金:江苏省自然科学基金资助项目(BK2004103),江苏省农机局基金资助项目(gxz08011)
摘  要:评价了用不同含量纳米SiC改性聚四氟乙烯(PTFE)复合材料的力学性能,利用MM-200型摩擦磨损试验机研究了纳米SiC含量对PTFE复合材料摩擦磨损性能的影响。借助于扫描电子显微镜观察分析了试样磨损表面形貌,并探讨其磨损机理。结果表明:纳米SiC能够提高PTFE复合材料的硬度,但复合材料的拉伸强度有所降低。纳米SiC能够增加PTFE复合材料的摩擦系数,降低其磨损量,当其质量分数为7%时,PTFE复合材料的耐磨损性能最佳。纳米SiC可以阻止PTFE带状结构的大面积破坏,以及在摩擦过程中于偶件表面能够形成转移膜并隔离复合材料与偶件的直接接触是减摩耐磨的主要原因。
Effects of nano-SiC on friction and wear properties of polytetrafluoroethylene (PTFE) were investigated using an MM-200 wear tester. Mechanical performances of PTFE composites were measured. Experimental results show that nano-SiC could reduce wear and increase friction coefficient of PTFE. Furthermore, it also increased hardness but the tensile strength of the composites decreased to some extent. When content is 7% in weight, the wear performance of PTFE composites is optimal. Worn surfaces of nano-SiC filled PTFE composites were observed using a scanning electron microscope. The reasons that the wear of PTFE is decreased are probably that nano SiC resisted severe mangle of PTFE strip structure, and that film transferred from counterpart surface prevented direct contact between PTFE composites and steel ring.
关 键 词:纳米碳化硅 聚四氟乙烯 复合材料 力学性能 摩擦磨损性能
nano SiC PTFE composites mechanical properties friction and wear properties
分 类 号: TB332 [工业技术 > 一般工业技术 > 工程材料学 > 复合材料]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (14篇)[1]邵鑫 田军 刘维民 马春林 薛群基.纳米Ti02填充聚醚砜酮复合材料的摩擦学性能[J].高分子材料科学与工程,2003,19(3):208-211.
[2]Wang Qihua, Xu Jinfen, et al. [J]. Journal of Applied Polymer Science, 1998, 69:2341-2347.
[3]颜红侠 宁荣昌 等.纳米Si3N4填充聚双马亚酰亚胺摩擦磨损性能研究[J].摩擦学学报,:.
[4]何春霞 沈惠平.纳米Al2O3填充聚四氟乙烯摩擦磨损性能的研究[J].摩擦学学报,:.
[5]Bijwe j, Logani C M, Tewari U S.[J].Wear, 1990, 138:77-92.
[6]Wang Qihua, Xue Qunji, Liu Weimin, et al. [J]. Wear, 2000, 243:140-146.
[7]王晓刚 刘永胜 等.SiC纳米材料制备及应用[J].西安科技学院学报,2002,22(4):440-443,447.
[8]纪秋龙 章明秋 容敏智 WETZELB FRIEDRICHK.纳米碳化硅填充环氧树脂复合材料的摩擦磨损特性[J].复合材料学报,2004,21(6):14.
[9]张招柱 薛群基 等.陶瓷颗粒填充PTFE复合材料的摩擦磨损性能研究[J].高分子材料科学与工程,:.
[10]Shangguan Qian qian, Cheng Xian-hua. On the friction and wear behavior of PTFE composite filled with rare earths treated carbon fibers under oil-lubricated condition[J]. Wear, 2006, 260(11-12): 1243-1247.
[11]杨丽君 王齐华 宁丽萍 杨景锋 赵普.碳纤维及石墨填充聚四氟乙烯复合材料的摩擦学性能研究[J].材料科学与工程学报,2004,22(5):705.
[12]曲建俊 李显凌 宋宝玉.碳纳米管改性聚四氟乙烯复合材料的摩擦磨损性能研究[J].摩擦学学报,2005,25(4):333-337.
[13]TangW, Zhu B L, Liu J J. [J]. Tribology, 2000, 20(1): 10-13.
[14]张招柱 薛群基.金属填充PTFE复合材料的摩擦磨损性能研究[J].高分子材料科学与工程,:.
纳米SiC改性PTFE复合材料的力学与摩擦磨损性能.pdf
529.62 KB, 下载次数: 0
GMT+8, 2026-7-15 00:30 , Processed in 1.181714 second(s), 11 queries , Redis On.
