查看: 2717|回复: 0
碱性燃料电池产过氧化氢阴极C/PTFE的制备及性能表征
发表于 2012-12-30 15:46:27 |江苏| 显示全部楼层 |阅读模式
Fabrication and Characterization of C/PTFE Cathode for Hydrogen Peroxide Synthesis through Alkaline Fuel Cell Reactor
作  者:徐源 宋天顺 徐夫元 陈英文 沈树宝
XU Yuan, SONG Tian-shun, XU Fu-yuan, CHEN Ying-wen, SHEN Shu-bao (National Engineering Research Center for Biochemistry, Nanjing University of Technology, Nanjing, Jiangsu 210009, China)
机构地区:南京工业大学国家生化工程技术研究中心,江苏南京210009
出  处:《过程工程学报》 CAS CSCD 2008年第8卷第2期 372-377页,共6页
Chinese Journal of Process Engineering
基  金:国家高技术研究发展计划(863)基金资助项目(编号:2006AA02Z211);江苏省省级污染防治专项资金资助项(编号:2006-1-W-19);江苏省自然科学基金资助项目(编号:BK2006181;BK2007188)
摘  要:研究了碱性燃料电池合成过氧化氢阴极碳/聚四氟乙烯(C/PTFE)的制备方法,考察了制备过程中的主要影响因素,并通过伏安曲线和过氧化氢浓度曲线及交流阻抗图谱,对不同条件下制备的阴极性能进行了评价.结果表明,压力、整平层碳含量及聚四氟乙烯含量对阴极性能均有较大影响,其中压力为10.0MPa、碳含量为0.2g及聚四氟乙烯含量为50%条件下制备的阴极能获得最大电流,过氧化氢的产量最高,2.5h后过氧化氢浓度达到56mmol/L.
A fabricating method of C-polytetraflouroethylene cathode, C/PTFE, for hydrogen peroxide synthesis through alkaline fuel cell reactor was studied, and the primary influential factors of fabrication were investigated. The performances of cathodes at different fabricating conditions were evaluated by the voltage-current curve, concentration curve of H2O2 and AC impendence diagram. The results showed that cathode performances were much affected by the pressure, carbon content and PTFE content in the flattening layer. When the pressure was 10.0 MPa, carbon content 0.2 g, and PTFE content 50%, the maximum current and high output of 1-1202 were produced, and the concentration of H2O2 reached 56 mmol/L after 2.5 h.
关 键 词:过氧化氢 碱性燃料电池 碳/聚四氟乙烯阴极 制备 性能表征
hydrogen peroxide alkaline fuel cell C/PTFE cathode fabrication characterization
分 类 号: TM911.4 [工业技术 > 电工技术 > 独立电源技术(直接发电) > 化学电源、电池、燃料电池]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (18篇)[1]Alcaide F, Cabot P L, Brillas E. Fuel Cells for Chemical and Energy Cogeneration [J]. J. Power Sources, 2006, 153: 47-60.
[2]Yamanaka I, Hashimoto T, Takenaka S, et al. Direct and Continuous Production of Hydrogen Peroxide with 93% Selectivity Using a Fuel-cell System [J]. Angew. Chem. Int. Ed., 2003, 42: 3653-3655.
[3]宋天顺 徐源 徐夫元 等.燃料电池型反应器产过氧化氢的研究进展[J].现代化工,2007,27(7):9-12.
[4]Yamanaka I, Hashimoto T, Otsuka K. Direct Synthesis of Hydrogen Peroxide (>1 wt%) over the Cathode Prepared from Active Carbon and Vapor-grown-Carbon-fiber by a New H2-O2 Fuel Cell System [J] Chem. Lett., 2002, 8: 852-853.
[5]郁青红 周明华 雷乐成.[J].物理化学学报,2006,22(7):883.
[6]Brillas E, Alcaide F, Cabot P L. A Small-scale Flow Alkaline Fuel Cell for on-site Production of Hydrogen Peroxide [J]. Electrochim. Acta, 2002, 48: 331-340.
[7]Yamanaka I, Onizawa T, Suzuki S, et al. Electrocatalysis of Heat-treated Mn-porphyrin/Carbon Cathode for Synthesis of H2O2 Acid Solutions by H2-O2 Fuel Cell Method [J]. Chem. Lett., 2006, 35(7) 1330-1331.
[8]Alcaide F, Brillas E, Cabot P L. EIS Analysis of Hydroperoxide Ion Generation in an Uncatalyzed Oxygen-diffusion Cathode [J]. J. Electroanal. Chem., 2003, 547: 61-73.
[9]Alcaide F, Brillas E, Cabot P L. Electrogeneration of Hydroperoxide Ion Using an Alkaline Fuel Cell [J]. J. Electrochem. Soc., 1998,145(10): 3444-3449.
[10]Lobyntseva E, Kallio T, Alexeyeva N, et al. Electrochemical Synthesis of Hydrogen Peroxide: Rotating Disk Electrode and Fuel Cell Studies [J]. Electrochim. Acta, 2007, 52(25): 7262-7269.
[11]Alcaide F, Brillas E, Cabot P L. Limiting Behaviour during the Hydroperoxide Ion Generation in a Flow Alkaline Fuel Cell [J]. J. Electroanal. Chem., 2004, 566: 235-240.
[12]Alcaide F, Brillas E, Cabot P L. Oxygen Reduction on Uncatalyzed Carbon-PTFE Gas Diffusion Cathode in Alkaline Medium [J]. J.Electrochem. Sot., 2002, 149(2): 64-70.
[13]李俊 赵玲 张新胜 等.燃料电池反应器中过氧化氢的生产:Ⅰ.实验研究[J].化学反应工程与工艺,2001,17(3):222-227.
[14]衣宝廉.燃料电池-原理·技术·应用[M].北京:化学工业出版社,2003..
[15]Arai H, Muller S, Haas O. AC Impedance Analysis of Bifunctional Air Electrodes for Metal-Air Batteries [J]. J. Electrochem. Soc., 2000,147(10): 3584-3591.
[16]Ahn S, Tatarchuk B J. Air Electrode: Identification of Intraelectrode Rate Phenomena via AC Impedance [J]. J. Electrochem. Soc., 1995, 142(12): 4169-4175.
[17]黄辉 卢焕明 等.多壁纳米碳管空气电极的交流阻抗研究[J].高等学校化学学报,2002(11):2151-2154.
[18]Alcaide F, Brillas E, Cabot P L. Impedance Study of the Evolution of a HOE- Generating Hydrophobic Gas Diffusion Electrode [J].Electrochem. Commun., 2002, 4: 838-843.
碱性燃料电池产过氧化氢阴极C/PTFE的制备及性能表征.pdf
315.63 KB, 下载次数: 0
GMT+8, 2026-7-15 00:29 , Processed in 0.044330 second(s), 8 queries , Redis On.
