查看: 2143|回复: 0
应用e-PTFE植入再造阴茎远端龟头成形术
发表于 2012-12-30 15:51:58 |江苏| 显示全部楼层 |阅读模式
Improving the appearance of the neoglans by implanting carved e-PTFE at the distal part of  the reconstructed phallus during phalloplasty
作  者:刘阳 程开祥 王善良 曹卫刚 李圣利
LIU Yang, CHENG Kai-xiang, WANG Shan-liang, CAO Wei-gang, LI Sheng-li (Department of Plastic and Reconstructive Surgery, Shanghai 9th People's Hospital, Medical College, Shanghai Jiaotong  University, Shanghai 200011, China)
机构地区:上海交通大学医学院附属第九人民医院整复外科,上海200011
出  处:《中国美容医学》 CAS 2008年第17卷第3期 330-332页,共3页
Chinese Journal of Aesthetic Medicine
摘  要:目的:使用膨体聚四氟乙烯(e-PTFE)植入再造阴茎体远端,使形成龟头以改善再造阴茎外形。方法:使用规格型号为0.5cm×5cm×6.5cm的e-PTFE块状材料雕刻成一上薄下厚,外光内糙的2/3圈圆锥状结构,包绕再造尿道,一期植入再造阴茎远端。结果:2002年~2007年共完成23例,再造阴茎全部成活,龟头形态良好,无植入物外露发生,2例发生尿瘘,1例因反复伤口感染而取出植入物。结论:阴茎再造时一期植入e-PTFE材料用于形成龟头,是一种安全、有效的阴茎再造龟头成形方法。
Objective To improve the appearance of the reconstructed phallus by implanting carved e-PTFE at the distal part of the neophallus. Methods A strip-shaped e-PTFE sized 0.5 cm × 1.5 cm × 6.5 cm was carved and sutured to form a structure like 2/3 circle pyramid , which was implanted at the distal part of the reconstructed phallus with the neourethra being wrapped within it. Results During 2002 to 2007, 23 male patients received phalloplasty by the way as the above, all reconstructed phalli survived completely with satisfactory appearance, implant exposure occurred in none case and urinary fistula occurred in 2 cases, in another 1 case the implant was dissected out at last for recurrent incision infections. Conclusion Implanting the carved e-PTFE to the distal part of the reconstructed phallus at the first stage of phalloplasty is a safe and effective way to make the neoglans with an acceptable appearance.
关 键 词:膨体聚四氟乙烯(e-PTFE) 阴茎再造术 龟头成形术
expanded polytetrafluoroethylene(e-PTFE) phalloplasty glans plasty
分 类 号: R622 [医药、卫生 > 外科学 > 整形外科学(修复外科学)]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (13篇)[1]Gilbert DA, Jordan GH. Devine C J, et al. Microsurgical forc-arm"cricket bat transformer"phalloplasty [J]. Plast Reconstr Surg, 1992.90(4):711-716.
[2]Gotllieb LJ, Levine LA. A new design for the radial forearm free flap phallic construction [J]. Plast Reconstr Surg, 1993,92(2 ):276-283.
[3]Santanelli F, Paolini G. Glans. Urethra and corporeal body reconstruction by free osteocutaneous forearm flap transfer [J]. Ann Plast Surg, 2003, 50(5):545-549.
[4]Hage JJ. A unique case of secondary microvascular glansplasty: the last genitoreconstructive frontier [J]? Ann Plast Surg, 2000, 45 (4):422-426.
[5]Sasaki K, Nozaki M, Morioka K et al. Penile reconstruction: Combined use of an innervated forearm osteocutancous flap and big toe pulp[J]. Plast Reconstr Surg, 1999,104(4): 1054-1058.
[6]Chang TS, Wang WY. Forearm flap in one stage reconstruction of the penis [J].Plast Reconstr Surg,1984,74(2):251-258.
[7]Kao XS, Kao JI-I, Ho CL, et al. One stage reconstruction of the penis with free skin flap:Report of three cases[J].Reconstr Micro Surg,1984,1(2):149-153.
[8]Cheng KX, Zhang RH, Zhou S, et al. Cheng's method for reconstruction of a functionally sensitive penis [J]. Plast Reconstr Surg, 1997,99(1):85-91.
[9]Jin HR, Lee JY, Yeon JY, et al. A multicenter evaluation of the safety of Gore-Tex as an implant in Asian rhinoplasty [J]. Am J Rhinol,2006,20(6):615-619.
[10]Inanli S, Sail M, Baylancicek S. The use of expanded polytetrafluoroethylene (Gore-Tex) in rhinoplasty[J]. Aesthetic Plast Surg,2007,31(4):345-348.
[11]Conrad K, Gillman G. A 6-year experience with the use of expanded polytetrafluoroethylene in rhinoplasty [J]. Plast Reconstr Surg,1998,101(6):
[12]Maas CS, Gnepp DR, Bumpous J. Expanded polytetrafluoroethylene(Gore-Tex soil-tissue patch) in facial augmentation [J]. Arch Otolaryngol Head Neck Surg, 1993,119(9): 1008-1014.
[13]程开祥 刘阳 谢芸.植入膨体聚四氟乙烯(e-PTFE)阴茎增粗术[J].中国美容医学,2007,16(9):1199-1201.
应用e-PTFE植入再造阴茎远端龟头成形术.pdf
403.08 KB, 下载次数: 1
GMT+8, 2026-7-15 00:28 , Processed in 0.044448 second(s), 10 queries , Redis On.
