查看: 2686|回复: 0
聚四氟乙烯微孔膜的透声性能实验
发表于 2012-12-31 07:00:10 |江苏| 显示全部楼层 |阅读模式
聚四氟乙烯微孔膜的透声性能实验
Measurement of Acoustic Performance of PTFE Microporous Membrane
作  者:刘晓松 娄文忠 刘爱丽 王永强
LIU Xiao-song, LOU Wen-zhong, LIU Ai-li, WANG Yong-qiang (School of Aerospace Science and Engineering, Beijing Institute of Technology, Beijing 100081, China)
机构地区:北京理工大学宇航科学技术学院,北京100081
出  处:《纳米技术与精密工程》 EI CAS CSCD 2008年第6卷第2期 85-88页,共4页
Nanotechnology and Precision Engineering
基  金:国防科工委基础研究项目(1020021200626).
摘  要:为研究微孔薄膜材料的透声性能,搭建了改进的四传声器阻抗管隔声量测试系统,推导了阻抗管中隔声量的传递损失矩阵算法,此算法可以有效地分离隔声管中透射波与二次反射波,使测试结果不受隔声管末端材料吸声性能的影响,与原四传声器算法相比物理意义更明确.对3种微孔薄膜样品进行了实验和分析,结果表明改进的测试方法可以精确地测试样品隔声量,尤其能提高低频段隔声量的测试精度,测试结果重复性优于原方法.
A new method of sound transmission loss measurement using a modified four-microphone impedance tube was proposed in this paper to investigate the microporous membrane's acoustic performance. Transmission loss matrix algorithm of the system was conducted with the physical meaning more clear than that of four-micro- phone impedance algorithm. The new algorithm effectively separated the transmission wave from the secondary reflected wave in the impedance tube and ensured the measurement result not to be influenced by absorbent end of the tube. Three types of microporous membrane were studied with new algorithm. The results indicate that the new method can raise the precision and repeatability of the measurement, especially in low frequency.
关 键 词:隔声量 传递损失矩阵算法 聚四氟乙烯(PTFE)微孔膜 四传声器
sound transmission loss transmission loss matrix algorithm PTFE microporous membrane four- microphone
分 类 号: TN16 [工业技术 > 无线电电子学、电信技术 > 真空电子技术]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (1篇)[1][6]Barnard Andrew R,Rao Mohan D.Measurement of sound transmission lose using a modified four-microphone impedance tube[C]//The 2004 National Conference on Noise Noise Control Engineering.Baltimore,Maryland,2004:12-14.
聚四氟乙烯微孔膜的透声性能实验.pdf
225.04 KB, 下载次数: 0
聚四氟乙烯微孔膜的透声性能实验
GMT+8, 2026-8-13 02:11 , Processed in 0.020488 second(s), 8 queries , Redis On.
