查看: 2440|回复: 0
Explosive Properties of the Mg-Al/PTFE Composition
发表于 2013-1-1 09:39:12 |江苏| 显示全部楼层 |阅读模式
作  者:Bogdan ZYGMUNT
机构地区:Military Technical University, Meehatronies Faculty, 2 Kaliski St. , 00 -905 Warsaw, Poland
出  处:《含能材料》 CAS CSCD 2007年第15卷第6期 592-596页,共5页
Chinese Journal of Energetic Materials
基  金:Acknowledgments: The author is deeply grateful to Dr. J. Paszula for his assistance during measurements of pressure impulses.
关 键 词:镁 铝 聚四氟乙烯 复合材料 爆炸性能 冲击波 爆炸压阻力 烟火器材
PTFE as oxidizer high-rate combustion blast wave explosive pressure resistance (EPR)
分 类 号: TB34 [工业技术 > 一般工业技术 > 工程材料学] TJ53 [工业技术 > 武器工业 > 爆破器材、烟火器材、火炸药]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (10篇)[1]European Standard No. EN 13124 - 1, Explosive Pressure Resistance [S]. 2001.
[2]Villey-Desmeserets F P A, Pouligen Y A, Guillauma G. US Pat. 3770525[ P]. 1973.
[3]Kubota N, Serlzawa C. Combustion process of Mg/PT pyrotechnics [ J]. Propellant, Explosives, Pyrotechnics, 1987,12 ( 5 ) : 145 - 151.
[4]Zygmunt B. at all. Patent RP nr 172343,1997.
[5]Zygmunt B. at all. Patent RP nr 175254,1998.
[6]Kuwahara T, Matsuo S, Shinozaki N. Combustion and sensitivity characteristics of Mg/TF pyrolants [ J ]. Propellants, Explosives, Pyrotechnics, 1997,22 (4) : 198 - 202.
[7]Bhingarkor V, Gandhi H, Phawode P, Singh H. Proc. 30th Int Annual Conference of ICT[ C ]. Karlsruhe, Germany, 1999 : 72 - 1.
[8]Cudzilo S. Analyse of burning process of the Me-PTFE composition ( in Polish) [ M]. Warszawa 2003 ,WAT, 57.
[9]Buczkowski D, Zygmunt B. The influence of physical structure of ammonium nitrate prills on detonation properties of ANFO[C]// Ⅵ Int. Seminar on New Trends in Research of Energetic Materials, University of Pardublce, Czech Rep, 2005 : 485 - 494.
[10]Griffits T T, Robertson J, Hall P G, et al. Proc. 10th Int. Pyrotechnics Seminar[ C]. p. V19 - 1 ,Karlsruhe,Germany,1985.
Explosive Properties of the Mg-Al_PTFE Composition.pdf
252.47 KB, 下载次数: 0
GMT+8, 2026-10-5 04:36 , Processed in 0.057221 second(s), 10 queries , Redis On.
