查看: 2799|回复: 0
电子束辐照接枝改性PTFE多孔膜
发表于 2013-1-1 09:45:18 |江苏| 显示全部楼层 |阅读模式
电子束辐照接枝改性PTFE多孔膜
Modification of polytetrafluoroethylene porous membranes by electron beam initiated surface grafting
作  者:奚振宇[1] 刘富[1] 杜宝山[2] 徐又一[1,2]
XI Zhen-yu, LIU Fu, DU Bao-shan, XU You-yi (1.Department of Polymer Science & Engineering, Zhejiang University, Hangzhou 310027,China;  2.Hangzhou Jiefu Membrane Technology Co., Ltd, Hangzhou 310027,China)
机构地区:[1]浙江大学材料与化学工程学院,高分子科学研究所,浙江杭州310027 [2]杭州洁弗膜技术有限公司,浙江杭州310027
出  处:《功能材料》 EI CAS CSCD 2007年第38卷第A07期 2738-2740页,共3页
Journal of Functional Materials
基  金:国家重点基础研究发展计划(973计划)资助项目(2003CB615705)
摘  要:通过高能电子束预辐照接枝丙烯酸(AA)/对苯乙烯磺酸钠(SSS)对PTFE多孔膜进行亲水改性,并研究了单体浓度、辐照剂量等对接枝率,接枝反应对多孔膜表面形貌膜和化学组成以及亲水性的影响。研究结果表明接枝率随混合单体中AA含量增加而增大,而且随辐照剂量的提高而增大,PTFE多孔膜的接枝覆盖层增加膜表面的亲水基团含量,同时对膜的亲水改性效果能保持稳定。
Polytetrafluoroethylene porous membranes were pre-irradiated by electron beam in vacuum, and then grafted with binary monomer solution of acrylic acid (AA) and sodium 4-styrenesulfonate (SSS). The effect of monomer condensation and irradiation dose on degree of grafting, and the surface morphological and chemical changes after grafting reaction, as well as the surface hydrophilicity of the modified membrane, were investigated. The results showed that the degree of grafting increased with AA content of binary monomers and irradiation dose. The surface grafting layer improved hydrophilicity and modifying stability of the porous membrane.
关 键 词:辐照 接枝 聚四氟乙烯 多孔膜
irradiation graft polytetrafluoroethylene porous membranes
分 类 号: O632 [数理科学和化学 > 化学 > 高分子化学(高聚物)] TB383 [工业技术 > 一般工业技术 > 工程材料学]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (6篇)[1]Klaus L, Uwe L, Ulrich S. [J]. J Fluo Chem, 2004, 125: 863-873.
[2]Liu Fu, Zhu Bao-Ku, Xu You-Yi. [J]. Appl Surf Sci, 2006, 253: 2096-2101.
[3]王渝芳 冯文 胡福敏 等.[J].四川大学学报:自然科学版,1997,34:335-339.
[4]Mohamed Mahmoud Nasef, Hamdani Saidi, Ahmed Mokhtar Dessouki, et al. [J]. Polym Int, 2000, 49: 399-406.
[5]闫宇 伊敏 翟茂林 等.[J].高分子学报,2004,(6):871-876.
[6]Zhang Jizhong, Ye Xiaoyan, Yu Xiaojun, et al. [J]. Mater Sci Eng, 2001, B84: 200-204.
电子束辐照接枝改性PTFE多孔膜.pdf
196.56 KB, 下载次数: 0
电子束辐照接枝改性PTFE多孔膜
GMT+8, 2026-7-14 23:12 , Processed in 0.031054 second(s), 11 queries , Redis On.
