查看: 4855|回复: 0
高强铝合金-PTFE纺织复合材料的摩擦磨损性能
发表于 2013-1-1 10:00:54 |江苏| 显示全部楼层 |阅读模式
Friction and Wear Properties of a High Strength  Al Alloy-PTFE Fabric Composite
作  者:舒伟才 向定汉
Shu Weicai Xiang Dinghan (College of Materials Science and Technology 'Nanjing University of Aeronautics and Astronautics, Nanjing Jiangsu 210016, China)
机构地区:南京航空航天大学材料科学与技术学院,江苏南京210016
出  处:《润滑与密封》 CAS CSCD 2007年第32卷第3期 55-57页,共3页
Lubrication Engineering
基  金:航空科学基金项目(04G52044).
摘  要:将PTFE纺织复合材料粘结到高强铝合金背衬上,制备成铝合金-PTFE纺织复合材料。选择航空工业常用的3层复合材料(DU)作对比实验。摩擦磨损实验在摆动实验机上完成,实验条件为:载荷为10—80MPa,摆动频率8次/min,摆角为±30。,相对湿度(70±5)%。实验结果证实铝合金-PTFE纺织复合材料的摩擦因数大约0.055,摆动磨损寿命大约2.5万次,均优于DU材料。可见,这种高比强的新型复合材料适用于航空航天工业。
An Al alloy-PTFE fabric composite was prepared, which is composed of polytetrafluoroethylene (PTFE) fabric as the matrix, and adhesive resin as the binder, and is cohered onto a high strength Al alloy support. Another kind of steel-bronze-PTFE composite (DU) was selected as a comparative investigation. Friction and wear tests were carried out in an Oscillating tribo-tester. Experimental conditions were normal pressure from 10 to 90 MPa,an oscillating frequentcy of 8 times per minute, oscillating angles of ± 30° and relative humidity of (70 ± 5 ) %. The result shows that the Al alloy-PTFE fabric composite exhibits a lower sible that the newly high specific coefficient of friction and longer oscillating wear life of 25 000 times than DU. So it is fea- strength composite is applied in aerospace.
关 键 词:纺织复合材料 聚四氟乙烯 磨损 自润滑轴承
fabric composite polytetrafluoroethylene wear self-lubricating bearing
分 类 号: TB333 [工业技术 > 一般工业技术 > 工程材料学 > 复合材料] TH117.1 [工业技术 > 机械、仪表工业 > 机械学(机械设计基础理论) > 机械摩擦、磨损与润滑]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (8篇)[1]L Zsidai,P De Baets,P Samyn,et al.The tribological behavior of engineering plastics during sliding friction investigated with small-scale specimens[J].Wear,2002,253:673-688.
[2]贾晓梅 王黎钦 古乐 郑德志 齐毓霖.聚苯酯填充聚四氟乙烯复合材料摩擦学行为研究[J].润滑与密封,2005(5):16-18.
[3]单昆仑 向定汉.短玻璃纤维和石墨填充PTFE的摩擦磨损特性研究[J].润滑与密封,2006(5):88-90.
[4]蔡立芳 黄承亚 易荣.Ekonol/石墨/MoS2填料对PTFE力学和摩擦磨损性能的影响[J].润滑与密封,2006(2):83-86.
[5]W G Sawyer,K D Freudenberg,P Bhimaraj,et al.A study on the friction and wear behavior of PTFEfilled with alumina nanoparticles[J].Wear,2003,254:573-580.
[6]GGB.DU/DU-B Dry Bearings,Disigner's Handbook[M].Glacier Metal Company Ltd,2004:13.
[7]苏峰华 张招柱 姜葳 王坤.纳米及微米颗粒改性玻璃纤维织物复合材料的摩擦磨损性能研究[J].摩擦学学报,2004,24(5):406-410.
[8]Feng-hua Sua,Zhao-zhu Zhang,Kun Wang,et al.Tribological and mechanical properties of the composites made of carbon fabrics modified with various methods[J].Compositesart A,2005,36:1601-1607.
高强铝合金-PTFE纺织复合材料的摩擦磨损性能.pdf
170.06 KB, 下载次数: 0
GMT+8, 2026-7-14 23:13 , Processed in 0.037001 second(s), 11 queries , Redis On.
