查看: 3047|回复: 0
聚四氟乙烯与蒙脱土填充聚苯硫醚复合材料的摩擦磨损性能
发表于 2013-1-1 10:02:09 |江苏| 显示全部楼层 |阅读模式
Tribologicai Properties in PTFE-fiiled and Bentonite-reinforced PPS Composites
作  者:向晓汉[1] 李科[2] 姚正军[2]
XIANG Xiao-han, LI Ke, YAO Zheng-jun (1. Wuxi Institute of Technology, Wuxi 214023, China; 2. Nanjing University of Aeronautics & Astronautics, Nanjing 210016, China)
机构地区:[1]无锡职业技术学院机电工程系,江苏无锡214023 [2]南京航空航天大学材料科学与技术学院,江苏南京210016
出  处:《机械工程材料》 CAS CSCD 2007年第31卷第10期 48-50页,共3页
Materials For Mechanical Engineering
基  金:航空科学基金资助项目(04G52044)
摘  要:通过模压成型制备出聚四氟乙烯(PTFE)和蒙脱土填充的聚苯硫醚(PPS)复合材料,研究了PTFE与蒙脱土的单独和协同作用对PPS摩擦磨损性能的影响。结果表明:单独添加PTFE能够显著降低PPS的摩擦因数和磨损率,同时填充PTFE与蒙脱土可以进一步改善PPS的摩擦学性能;PPS+15%PTFE+59/5蒙脱土复合材料的比磨损率最低,为0.69×10^-4 mm^3/Nm,其摩擦因数也最小,约为0、15。
Polytetrafluoroethylene ( PTFE)-filled and bentonite-reinforced polyphenylene sulfide (PPS) composites were prepared by compression molding. The behaviors of PPS materials and the synergism as a result of the incorporation of both the PTFE and the bentonite were investigated. Friction and wear tests were carried out in a reciprocating sliding tribometer. Results show that the addition of PTFE only led to reducing a friction coefficient and specific wear rate of the PPS. The tribological properties of the PPS composites filled with both the PTFE and the bentonite are further improved. The lowest wear rate are found in the ease of the PPS+15NPTFE +5N bentonite composite,0.69×10^-4 mm^3/Nm. The friction coefficient is about 0. 15.
关 键 词:聚苯硫醚 聚四氟乙烯 蒙脱土 摩擦磨损
polyphenylene sulfide (PPS) polytetrafluoroethylene (PTFE) bentonite friction and wear
分 类 号: TH117.1 [工业技术 > 机械、仪表工业 > 机械学(机械设计基础理论) > 机械摩擦、磨损与润滑]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (8篇)[1]Cho M, Bahadur S. Study of the tribological synergistic effects in nano CuO-filled and fiber-reinforced polyphenylene sulfide composites[J].Wear, 2005,258(5/6) : 835- 845.
[2]金栋 崔小明.聚苯硫醚的生产应用及市场前景[J].化学推进剂与高分子材料,2001,82(4):25-28.
[3]Schwartz C, Bahadur S. Studies on the tribologieal and transfer film-eounterfaee bond strength of polyphenylene sulfide filled with nanoseale alumina particles[J]. Wear, 2000, 237 (2):261-273.
[4]何志敏 张大伦 张文栓 罗运军.聚苯硫醚/聚四氟乙烯复合材料的研究[J].塑料,2005,34(2):59.
[5]Bahadur S, Sunkara C. Effect of transfer film structure, composition and bonding on the tribological behavior of polyphenylene sulfide filled with nano particles of TiO2, ZnO, CuO and SiC[J].Wear, 2005,258(9): 1411-1421.
[6]Cho M, Bahadur S, Pogosian A. Friction and wear studies using taguchi method on polyphenylene sulfide filled with a complex mixture of MoS2, Al2O3, and other compounds [J ]. Wear, 2005,258 (11/12 ) : 1825 - 1835.
[7]Czichos H, Klaffke D, Santner E. Advances in tribology: the materials point of view[J]. Wear, 1995,190(2) : 155-161.
[8]李小慧 潘钢梁 王文东.辐照交联对聚丙烯复合材料性能的影响[J].机械工程材料,2005,29(12):56-58.
聚四氟乙烯与蒙脱土填充聚苯硫醚复合材料的摩擦磨损性能.pdf
189.58 KB, 下载次数: 2
售价: 1 氟币  [记录]
GMT+8, 2026-10-5 04:36 , Processed in 0.036827 second(s), 11 queries , Redis On.
