查看: 3277|回复: 0
聚四氟乙烯结构氟碳聚合物薄膜的研究进展
发表于 2013-1-1 10:11:02 |江苏| 显示全部楼层 |阅读模式
聚四氟乙烯结构氟碳聚合物薄膜的研究进展
Advances in the Study of Polytetrafluoroethylene- like  Fluorocarbon Film Deposition
作  者:谷建东[1] 李东明[1] 冯志庆[2] 牛金海[2] 刘东平[2]
GU Jian - dong. LI Dong - ming, Feng Zhi - qing, NIU Jin - hai, LIU Dong - ping  (1. School of Mechanical Engineering, Dalian Jiaotong University, Dalian Liaoning, 116028, China;  2. Institute of Optoelectronic Technology, Dalian Nationalities University, Dalian Liaoning, 116605, China)
机构地区:[1]大连交通大学机械工程学院,辽宁大连116028 [2]大连民族学院光电子技术研究所,辽宁大连116605
出  处:《大连民族学院学报》 CAS 2007年第9卷第5期 130-133页,141页,共5页
Journal of Dalian Nationalities University
摘  要:聚四氟乙烯结构氟碳聚合物(Polytetrafluoroethylene-like fluorocarbon,PIFE-like FC)薄膜具有超低介电常数、高疏水性和生物相容性等优点.综述了国外制备PIFE-like FC薄膜的实验进展,分析了PTFE—like FC薄膜可能的沉积机理,指出热丝化学气相沉积(HFCVD)和射频等离子体辅助的化学气相沉积(rf—PECVD)这2种方法更有利于减少离子对薄膜表面的轰击作用,被认为是目前沉积PIFE-like FC薄膜最好的2种方法.介绍了利用介质阻挡放电(DBD)方法在低气压下制备FIFE-likeFC薄膜的最新进展.
Bulk polytetrafluoroethylene [ PTFE, (CF2)n] has many remarkable properties, includiilg a low dielectric constant, hydrophobility and biocompatibility. In this paper, the theory and the process of the experiment and the majority of proposed mechanisms are introduced. Plasma enhanced chemical vapor deposition and hot wire chemical vapor deposition are considered to be the two best methods for PTFE - like FC thin film deposition, because they are more beneficial to reduce ion bombardment. Also we introduce our recent research process of depositing PTFE - like FC thin films using dielectric barrier discharge (DBD) method under low pressure.
关 键 词:介电常数 氟碳聚合物薄膜 等离子体辅助化学气相沉积 热丝化学气相沉积
dielectric constant fluorocarbon film plasma enhanced chemical vapor deposition hot wire chemical vapor deposition
分 类 号: O484.1 [数理科学和化学 > 物理学 > 固体物理学 > 薄膜物理学]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (22篇)[1]Lau K K S,Murthy S K,Lewis H G P,et al.Fluorocarbon Dielectrics via Hot Filament Chemical Vapor Deposition[J].J.Fluorine Chem.,2003,122 (1):93-96.
[2]Nitschke M,Uhlmann S,Schulze R,et al.Plasma polymerization of tetrafluoroethylene-towards CF2 dominated fluorocarbon films[J].e-Polymers,2006,006.
[3]Lau K K S,Bico J,Teo K B,et al.Superhydrophobic Carbon Nanotube Forests[J].Nano Lett,2003,3 (12):1701 -1705.
[4]Carmen I B,Neil M M,Jeffrey L B,et al.Control of Surface Film Composition and Orientation with Downstream PECVD of Hexafluoropropylene Oxide[ J].Chem.Mater.,1999,11 (4):862-864.
[5]Butoi C I,Mackie N M,Gamble L J,et al.Deposition of Highly Ordered CF2 -Rich Films Using Continuous Wave and Pulsed Hexafluororopylene Oxide Plasmas[ J].Chem.Mater.,2000,12 (7):2014-2024.
[6]Rastogi A C,Desu S B.Characterization of low pressure chemical vapor deposited polymeric fluorinated carbon m (C:Fx) n thin films with low dielectric constant[J].Appl.Phys.A,2006,83 (1):57-66.
[7]Lau K K S,Lewis H G P,Limb S J,et al.Hot-wire chemical vapor deposition (HWCVD) of fluorocarbon and organosilicon thin films[J].Thin Solid Films,2001,395(1-2):288-291.
[8]Lau K K S,Caulfield J A,Gleason K K.Structure and Morphology of Fluorocarbon Films Grown by Hot Filament Chemical Vapor Deposition[ J].Chem.Mater.,2000,12 (10):3032 -3037.
[9]Rastogi A C,Desu S B.Thermal chemical vapor deposition of fluorocarbon polymer thin films in a hot filament reactor[J].Polymer,2005,46 (10):3440-3451.
[10]Milella A,Palumbo F,Favia P,et al.Continuous and Modulated Deposition of Fluorocarbon Films from c -C4F8 Plasmas[J].Plasma Process.Polym.,2004,1 (2):164-170.
[11]Cicala G,Milella A,Palumbo F,et al.Morphological and structural study of plasma deposited fluorocarbon films at different thicknesses[J].Diamond and Related Materials,2003,12 (10-11):2020-2025.
[12]Shibagaki K,Maeda T,Takada N,et al.Laser desorption time -of-flight mass spectrometry of fluorocarbon films synthesized by C4F8/H2 plasmas[J].J.Vac.Sci.Technol.A,2003,21 (4):866-873.
[13]Bogart K H A,Dalleska N F,Bogart G,et al.Plasma enhanced chemical vapor deposition of silicon dioxide using novel alkoxysilane precursors[J].J.Vac.Sci.Technol.A,1995,13 (2):476-480.
[14]Butoi C I,Mackie N M,Williams K L,et al.Ion and substrate effects on surface reactions of CF2 using C2F6,C2F6/H2,and hexafluoropropylene oxide plasmas[J].J.Vac.Sci.Technol.A,2000,18 (6):2685-2698.
[15]Martin I T,Fisher E R.Ion effects on CF2 surface interactions during C3F8 and C4F8 plasma processing of Si[J].J.Vac.Sci.Technol.A,2004,22 (5):2168-2176.
[16]Martin I T,Zhou J,Fisher E R.Correlating ion energies and CF2 surface production during fluorocarbon plasma processing of silicon[J].J.Appl.Phys.,2006,100(1):013301 -1-013301-10.
[17]Liu Dong-ping,Martin I T,Fisher E R.CF2 surface reactivity during hot filament and plasma-enhanced chemical vapor deposition of fluorocarbon films[ J].Chemical Physics Letters,2006,430 (1 -3):113 -116.
[18]Liu Dong-ping,Marin I T,Jie zhou,et al.Radicalsurface interactions during film deposition:A sticky situation?[J].Pure Appl.Chem.,2006,78 (6):1187-1202.
[19]叶超 宁兆元 程珊华 辛煜 许圣华.氟化非晶碳薄膜的低频介电性质分析[J].功能材料,2004,35(3):338-340.
[20]吴振宇 杨银堂 汪家友.微波电子回旋共振等离子体化学气相淀积法制备非晶氟化碳薄膜的研究[J].物理学报,2006,55(5):2572-2577.
[21]Qi H J,Fu Y B,Wang D,et al.SEM study of fluorocarbon films by R.F.sputtering PTFE targets on PET substrates[J].Surface and Coatings Technology,2000,131 (1 -3):177-180.
[22]Li Wei,Tan Xiaodong,Liu Dongping,et al.Growth of fluorocarbon films by low-pressure dielectric barrier discharge (060170)[J].Plasma Science & Technology,2007,9.
聚四氟乙烯结构氟碳聚合物薄膜的研究进展.pdf
286 KB, 下载次数: 0
聚四氟乙烯结构氟碳聚合物薄膜的研究进展
GMT+8, 2026-10-24 23:21 , Processed in 0.020478 second(s), 9 queries , Redis On.
