查看: 3150|回复: 0
填充材料对聚四氟乙烯基复合材料摩擦学特性的影响
发表于 2013-1-1 10:13:59 |江苏| 显示全部楼层 |阅读模式
Effects of Fillers on the Tribological Properties of  Polytetrafluoroethylene Based Composites
作  者:陈刚 焦明华 解挺 俞建卫
CHEN Gang, JIAO Ming- hua, XIE Ting, YU Jian -wei ( Institute of Tribology, Hefei University of Technolohy, Hefei 230009, China)
机构地区:合肥工业大学摩擦学研究所,合肥230009
出  处:《轴承》 2007年第10期 42-45页,共4页
Bearing
摘  要:聚四氟乙烯基复合材料是重要的自润滑材料,应用广泛。根据填充材料的类别不同对聚四氟乙烯基复合材料进行了合理地分类,并阐述了不同填料对聚四氟乙烯基复合材料摩擦学特性的影响,分析和比较了不同填料的减摩抗磨机理,对于聚四氟乙烯基复合材料的科学研究和工程应用具有一定的借鉴和指导意义。
The polytetrafluorecthylene (PTFE) based composites, as significant serf-lubricating materials, have been widely used, and they are one of the hottest research fields in polymer composites. In this paper, the FIFE based composites were classified reasonably into several types according to the sorts of fillers. The effects of different fillers on the tribological properties of FIFE composites were systematically presented, meanwhile, the anti-friction and anti-wear mechanisms of different fillers were also analyzed and compared in detail, which are good references and of great guidance significance for the reseach and engineering application of FIFE composites.
关 键 词:聚四氟乙烯 复合材料 填充材料 摩擦 磨损
Polytetrafluoroethylene composite filler friction wear
分 类 号: TH133.31 [工业技术 > 机械、仪表工业 > 机械零件及传动装置 > 转动机件 > 轴承] TQ325.4 [工业技术 > 化学工业 > 合成树脂与塑料工业 > 聚合类树脂及塑料]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (23篇)[1]王承鹤.塑料摩擦学-塑料的摩擦、磨损、润滑理论及实践[M].北京:机械工业出版社,1994..
[2]回素彩 陈旭.填充改性聚四氟乙烯复合材料的性能[J].塑料工业,2004,38(4):4--8.
[3]王家序 陈战 等.填料对聚四氟乙烯工程塑料改性的影响[J].机械工程材料,:.
[4]张招柱 薛群基.金属填充PTFE复合材料的摩擦磨损性能研究[J].高分子材料科学与工程,:.
[5]GONG De - li, ZHANG Bing, XUE Qun - ji, et al. Investigation of Adhesion Wear of Filled Polytetrafluoroethylene by ESCA,AES and XRD[ J] . Wear, 1990,57 : 25 - 39.
[6]杨生荣 刘维民 薛群基.铜纤维增强PTFE复合材料磨损表面的SEM研究[J].电子显微镜学报,1998,17(5):641-642.
[7]札生荣.金属纤维增强PTFE基复合材料的摩擦学性能[J].摩擦学学报,:.
[8]Unal H,Mimaroglu A,Kadioglu U,et al. Sliding Friction and Wear Behaviour of Polytetrafluoroethylene and Its Composites under Dry Conditions [ J ]. Materials and Design,2004,25:239 - 245.
[9]杨丽君 王齐华 宁丽萍 杨景锋 赵普.碳纤维及石墨填充聚四氟乙烯复合材料的摩擦学性能研究[J].材料科学与工程学报,2004,22(5):705.
[10]陈战 王家序 等.聚四氟乙烯工程材料的摩擦磨损性能研究[J].机械工程学报,2002,38(4):74-77.
[11]孙春峰 李丽 等.碳纤维增强聚四氟乙烯耐磨材料的研究[J].塑料工业,2002,30(4):25.
[12]Chen W X, Li F, Hart G, et al. Tribological Behavior of Carbon - nanotube - filled PTFE Composites [ J ]. Tribology Letters ,2003,15 ( 3 ) :275 - 278.
[13]Kyuichlro Tanaka, Satoshi Kawakami. Effect of Various Fillers on the Friction and Wear of Polytetrafluoroethylene - based Composites[ J]. Wear, 1982,79:221.
[14]张招柱 薛群基.金属硫化物及石墨填充PTFE复合材料的摩擦磨损性能研究[J].复合材料学报,:.
[15]张招柱 薛群基.几种金属氧化物填充聚四氟乙烯复合材料在干摩擦条件下的摩擦磨损…[J].摩擦学学报,:.
[16]张招柱 薛群基 等.纤维及晶须增强PTFE复合材料的摩擦磨损性能研究[J].高分子材料科学与工程,2001,17(4):90.
[17]何春霞 王耀华.Al2O3纤维填充PTFE复合材料摩擦磨损性能分析[J].机械工程材料,:.
[18]李飞 阎逢元.纳米ZnO填充的PTFE基复合材料摩擦学性能研究[J].润滑与密封,:.
[19]ZHANG Zhao - Zhu, XUE Qun - Ji, LIU Wei - Min, et al. Effect of Rare Earth Compounds as Fillers on Friction and Wear Behaviors of PTFE - Based Composites [ J ]. Journal of Applied Polymer Science, 1999,72 : 361 - 369.
[20]张洪波 贾鹏 董允 等.SiC颗粒增强PTFE基复合材料摩擦磨损性能研究[J].河北工业大学学报,2004,33(5):38-42.
[21]张招柱 薛群基 等.陶瓷颗粒填充PTFE复合材料的摩擦磨损性能研究[J].高分子材料科学与工程,:.
[22]赵普 刘近朱 王齐华 杨丽君 李旭玲.聚苯酯、聚酰亚胺填充聚四氟乙烯复合材料的摩擦学性能研究[J].材料科学与工程学报,2003,21(6):851.
[23]贾晓梅 王黎钦 古乐 郑德志 齐毓霖.聚苯酯填充聚四氟乙烯复合材料摩擦学行为研究[J].润滑与密封,2005(5):16-18.
填充材料对聚四氟乙烯基复合材料摩擦学特性的影响.pdf
223.12 KB, 下载次数: 10
售价: 1 氟币  [记录]
GMT+8, 2026-7-14 22:53 , Processed in 0.151001 second(s), 11 queries , Redis On.
