查看: 3241|回复: 0
可粘性聚四氟乙烯板材的制备工艺和粘合性能
发表于 2013-2-3 17:30:52 |江苏| 显示全部楼层 |阅读模式
付朝霞[1] 段玉丰[2] 葛艳蕊[3][1]河北科技大学科研处,河北石家庄050018 [2]河北科技大学材料科学与工程学院,河北石家庄050018 [3]河北科技大学化学与制药工程学院,河北石家庄050018
摘 要:研究了可粘性聚四氟乙烯(PTFE)板材的制备工艺及其粘合性能.确定了加工工艺参数,讨论了添加剂LW和经表面处理的LW对树脂粘合性能的影响.实验结果显示:通过在PTFE中混合LW,可以有效改善PTFE板材的粘合性能;当采用硅烷偶联剂KH550、十六烷基溴化胺对LW表面进行处理,粘合性能可以进一步提高,并且硅烷偶联剂KH550处理LW的效果更好.[著者文摘]
关键词TFE 粘合性能 添加剂LW 表面处理
分类号: TQ225.13[著者标引]文献标识码:A文章编号:1000-5854(2007)05-0645-03栏目信息:化学
Preparing Technology of Cohesible Poly(tetrafluoroethylene) Board and Its Adhesion PropertyFU Zhao-xia, DUAN Yu-feng, GE Yan-rui 1. Division of Science and Researeh,Hebei University of Science and Teehnology,Hebei Shiiiazhuang 050018,China; 2. College of Material Science and Engineering,Hebei University of Science and Teehnology,Hebei Shijiazhuang 050018,China; 3. College of Chemical and Pharmeeutical Engineering,Hebei University of Science and Teehnology,Hebei Shiiiazhuang 050018,ChinaAbstract:The technology of preparing coheslble poly(tetrafluoroethylene)(PTFE) board and regarding adhesion property were discussed. The effects of additive LW and surface treated additive LW with hexadecyltrimethylammonium bromide (CTAB)and silane coupling agent KH550 were discussed. Experimental data showed the adhesion strength of PTFE board was improved through adding additive LW. Higher adhesion strength was achieved by adding the treated additive LW with CTAB and silane coupling agent KH550.[著者文摘]
Key wordsTFE; adhesion property ; additive LW ; surface treatment
可粘性聚四氟乙烯板材的制备工艺和粘合性能.pdf
186.57 KB, 下载次数: 3
GMT+8, 2026-10-26 09:54 , Processed in 0.028069 second(s), 9 queries , Redis On.
