查看: 2685|回复: 0
改性PTFE纤维金属配合物的制备及其光催化降解性能
发表于 2013-4-14 18:17:15 |江苏| 显示全部楼层 |阅读模式
丁志忠[1] 董永春[1,2] 李冰[1] 李淼[1][1]天津工业大学纺织学院纺织化学与生态研究中心,天津300387 [2]福州大学光催化国家重点实验室培育基地,福州350002
摘 要:使用聚丙烯酸接枝改性聚四氟乙烯(PAA-g-PTFE)纤维分别与Fe3+及其与Cu2+的混合物反应制备改性PTFE纤维铁和铁铜双金属配合物,并分别使用傅里变换叶红外(FTlR)光谱和紫外-可见(uv-vis)漫反射光谱(DRS)对两种配合物的化学结构和光吸收性能进行表征.然后将两种配合物分别作为非均相光Fenton反应催化剂应用于典型偶氮染料活性蓝222氧化降解反应中,考察和比较了二者在不同pH介质中对降解反应的催化作用.结果表明,在有或无Cu2+的存在条件下,一个Fe3+能够与三个PAA-g-PTFE表面的6个羧基发生反应形成配合物,并且它们在紫外和可见光区表现出好的光吸收特性.当两种金属离子共存时Cu2+比Fe3+更容易与PAA-g-PTFE发生配位反应形成铁铜双金属配合物.在可见光辐射下PAA-g-PTFE铁配合物对不同pH水溶液中染料降解反应均表现出显著的催化作用,但是溶液pH的升高不利于配合物催化活性的发挥.而配合物中铁离子含量提高特别是引入Cu2+作为助金属离子能够较大幅度地改善其在高pH范围内的催化活性和重复利用性.[著者文摘]
关键词:聚四氟乙烯纤维 金属配合物 配位结构 光催化 Fenton反应 染料降解
分类号: O643.2[著者标引]文献标识码:文章编号:栏目信息:催化和表面科学
相关文献:主题相关
Preparation of Grafted PTFE Fiber Metallic Complexes and Their Photocatalytic Degradation AbilitiesDING Zhi-Zhong DONG Yong-Chun LI Bing LI Miao1Division of Textile Chemistry & Ecology, School of Textiles, Tianjin Polytechnic University, Tianjin 300387, P R. China; 2State Key Laboratory Breeding Base of Photocatalysis, Fuzhou University, Fuzhou 350002, P. R. ChinaAbstract: Polyacrylic acid grafted polytetrafluoroethylene (PAA-g-PTFE) fibers were coordinated with Fe3+ ions and with a mixture of Cu2+ and Fe3+ ions to prepare PAA-g-PTFE Fe and Cu-Fe bimetallic complexes. The chemical structures and light adsorption properties of the complexes were characterized using Fourier transform infrared (FTIR) spectrometry and UV-Vis diffuse reflection spectroscopy (DRS), respectively. The complexes were used as heterogeneous photo-Fenton catalysts in the oxidative degradation of the azo dye, Reactive Blue 222, in different pH aqueous media. The results indicate that Fe3+coordinates with six carboxyl groups grafted on the surface of PAA-g-PTFE in the presence or absence of Cu2+ ion, and improved light adsorption properties are achieved in the UV and visible regions. When both metal ions coexist in solution, the Cu2+ ion coordinates more easily with PAA-g-PTFE than Fe3+ to produce a PAA-g-PTFE Cu-Fe bimetallic complex. Moreover, PAA-g-PTFE Fe significantly increases the degradation of Reactive Blue 222 in the pH range 3-9 under visible irradiation. However, at high pH conditions (〉7) the catalytic ability is reduced. Increasing the Fe content, and especially incorporating Cu2+ ions in the complex, dramatically improves the catalytic reusability at high pH value.[著者文摘]
Key words: Polytetrafluoroethylene fiber; Metallic complex; Coordination structure; Photocatalysis Fenton reaction; Dye degradation
收稿日期: 2012-08-20修订日期: 2012-10-15基金资助:天津市应用基础与前沿技术重点研究计划(11JCZDJC24600)和国家自然科学基金(20773093)资助项目
作者简介:Corresponding author. Email: dyefib@yahoo.com.cn; Tel: +86-22-83955359.
改性PTFE纤维金属配合物的制备及其光催化降解性能.rar
625.15 KB, 下载次数: 0
GMT+8, 2026-7-14 22:54 , Processed in 0.019657 second(s), 11 queries , Redis On.
