查看: 2849|回复: 0
TRANSITION IN THE MELT OF FEP COPOLYMER
发表于 2013-7-21 08:20:35 |江苏| 显示全部楼层 |阅读模式
【作者】 史观一; 乐俊士;
【Author】 SHI Guanyi YUE Junshi (Shanghai Institute of Organic Chemistry, Academia Sinica, Shanghai)
【机构】 Shanghai Institute of Organic Chemistry Academia Sinica Shanghai; Shanghai Institute of Organic Chemistry Academia Sinica Shanghai;
【摘要】 <正> The nature of the transition in molten FEP copolymer was examined in relation to the enthalpy change, mechanical damping and melt viscosity. For a pre-heat-treated FEP copolymer sample a small endothermic peak appeared at 309—312 ℃in DSC trace with enthalpy change 0.03—0.05 cal/g. A peak was also detected in damping versus temperature curve at the same temperature range. The theological property of FEP copolymer melt was similar to that of liquid crystal, but no birefrigence was viewed... 更多还原
【关键词】 科学通报; 史观; 高分子; 通讯;
【参考文献】 说明:反映本文研究工作的背景和依据
全部 中国学术期刊网络出版总库 中国博士学位论文全文数据库 中国优秀硕士学位论文全文数据库 中国重要会议论文全文数据库 国际会议论文全文数据库 中国重要报纸全文数据库 中国专利数据库 中国标准数据库 中国图书全文数据库 中国年鉴网络出版总库 Springer期刊数据库 外文题录数据库
中国学术期刊网络出版总库共找到 1 条
[1] 史观一,乐俊士.  四氟乙烯-六氟丙烯共聚物的结晶机制[J]. 科学通报. 1982(03)
Springer期刊数据库共找到 2 条
[1] Lisa R. Denny,Raymond F. Boyer.  Thermal evidence for a transition above Tm in n-alkanes and crystalline polymers[J]. Polymer Bulletin . 1981 (9)
[2] M. Pietralla,J. K. Krüger.  Are there two temperature regions with different structure of N-alkane melts?[J]. Polymer Bulletin . 1980 (10) 外文题录数据库共找到 2 条
[1] Krüger,J. K. Solid State Communications . 1979
[2] Eby,R. K. J. Applied Physics . 1966
TRANSITIONINTHEM_省略_LTOFFEPCOPOLYMER_史观一.pdf
671.85 KB, 下载次数: 0
GMT+8, 2026-8-6 05:13 , Processed in 0.019852 second(s), 8 queries , Redis On.
