查看: 3503|回复: 0
植入膨体聚四氟乙烯(e-PTFE)阴茎增粗术
发表于 2009-4-16 20:26:34 |江苏| 显示全部楼层 |阅读模式
摘 要:目的:使用膨体聚四氟乙烯(e-PTFE)植入阴茎体远端,增粗阴茎体、改善性生活和减轻性心理压力。方法:使用条状e-PTFE材料,体积0.5cm×1.5 cm×6.5cm雕刻成"C"形植入阴茎远端白膜表面。结果:从1998年12月~2006年12月共完成43例。阴茎体远端直径平均增加7~9mm,性生活有不同程度的改善。其中2例就医者因切口感染造成手术失败。结论:阴茎部分增粗能够改善就医者的性生活,减轻就医者的性心理压力。
Abstract:Objective Implant e-PTFE to the distal part of phallus to augment the phallus and ameliorate sexual life quality. Methods A strip-shaped e-PTFE sized 0.5cm×1.5cm×6.5cm was sculptured into 'C' shape and was implanted to the distal part of phallus at the superficial layer of tunica albuginea. Results 43 patients were treated from December 1998 to December 2006. The diameters at the distal part of phalli increased 7-9mm in average. And the patients' sexual life quality was ameliorated in different extent. Two cases failed due to the infection of incision. Conclusion Phallus augmentation can ameliorate patients' sexual life quality and alleviate the psychological stress.
植入膨体聚四氟乙烯(e-PTFE)阴茎增粗术.pdf
568.49 KB, 下载次数: 24
GMT+8, 2026-7-14 23:11 , Processed in 0.019936 second(s), 10 queries , Redis On.
