查看: 4401|回复: 0
PTFE的辐射交联及其应用
发表于 2009-4-25 16:07:57 |江苏| 显示全部楼层 |阅读模式
摘 要:利用电子束高温辐照PTFE,制备出交联PTFE样。通过红外光谱法(IR)、差示扫描量热分析法(DSC)等各种方法研究辐射交联PTFE的性能。结果表明:与未辐照PTFE相比,交联PTFE的透明度明显增加,熔点下降,耐磨性能明显提高。
关键词:聚四氟乙烯 辐射交联 辐射裂解
Abstract:Radiation - crosslinking of polytetrafluoroethylene was carried out at high temperature and the products were analyzed by various methods. It was shown that the crosslinked PTFE had a good transparency and lower melting point. In addition, abrasion resistance and the tensile strength of PTFE are also greatly improved by radiation crosslinking.
Key words:polytetrafluoroethylene ; radiation crosslinking
PTFE的辐射交联及其应用.pdf
308.1 KB, 下载次数: 45
GMT+8, 2026-7-14 23:11 , Processed in 0.018757 second(s), 10 queries , Redis On.
