查看: 9149|回复: 4
[疑问求助] 国外FEP标准
 火.. [复制链接]
发表于 2010-2-22 19:14:32 |江苏| 显示全部楼层 |阅读模式
国外FEP F46标准:http://www.myptfe.com/Teflon/Knowledge/200907/760.html
序号
标准名称
英文名称
公布年份
FEP-1
电气用塑料膜规范.第3部分:个体材料规范.第7章:电气绝缘用FEP膜的要求
(Specification for plastic films for electrical purposes. Part 3 : specifications for individual materials. Sheet 7 : requirements for fluoroethylene-propylene (FEP) films used for electrical insulation.)
1998
FEP-2
通信电缆.第2-30部分:一般设计规则和制造.四氟乙烯和六氟乙烯共聚物(FEP)绝缘和铠装
(Communication cables - Part 2-30 : common design rules and construction - Poly(tetrafluoroethylene-Hexafluoropropylene) (FEP) insulation and sheathing.)
2002
FEP-3
通信电缆 第2-30部分:通用的设计原理及结构 聚(四氟乙烯-六氟烯)(FEP)绝缘及包复物
Communication cables - Part 2-30: Common design rules and construction; Poly(tetrafluoroethylene-hexafluoropropylene) (FEP) insulation and sheathing / Note: Applies only in conjunction with EN 50290-2-20
2002
FEP-4
FEP碳氟化合物管规范(08.03)
Specification for FEP-Fluorocarbon Tubing (08.03)
1998
FEP-5
FEP碳氟化合物树脂薄板和薄膜(08.03)
FEP Fluorocarbon Resin Sheet and Film (08.03)
1999
FEP-6
KT型(250V)、K型(600V)和KK型(1000V)电和电子FEP(氟乙烯丙烯)绝缘高温架空电线
Electrical and Electronic FEP (Fluorinated Ethylene Propylene)-Insulated High Temperature Hook-Up Wire, Types KT (250 Volt), K (600 Volt) and KK (1000 Volt)
2000
FEP-7
FEP-碳氟化合物管的标准规范
Standard Specification for FEP-Fluorocarbon Tube
2003
FEP-8
FEP氟化乙丙烯模制和压塑材料的标准规范
Standard Specification for FEP-Fluorocarbon Molding and Extrusion Materials
2002
FEP-9
氟化乙丙烯(FEP)-碳氟化合物树脂薄板及薄膜的标准规范
Standard Specification for FEP-Fluorocarbon Resin Sheet and Film
2004
FEP-10
电气用塑料薄膜规格.专用材料的规格.电气绝缘用氟乙烯-丙烯薄膜的要求
Specification for plastic films for electrical purposes - Specifications for individual materials - Requirements for fluoroethylene-propylene (FEP) films used for electrical insulation
1995
FEP-11
通信电缆.通用设计规则和制造.聚四氟乙烯 - 聚六氟丙烯(FEP)绝缘和铠装化合物
Communication cables - Common design rules and construction - Poly(tetrafluoroethylene-hexafluoropropylene) (FEP) insulation and sheathing
2002
FEP-12
通信电缆.第2-30部分:通用设计规则和结构.聚四氟乙烯-六氟丙烯(FEP)绝缘材料和护套; 德文版本 EN 50290-2-3
Communication cables - Part 2-30: Common design rules and construction; Poly(tetrafluoroethylene-hexafluoropropylene) (FEP) insulation and sheathing; German version EN 50290-2-30:2002
2002
FEP-13
电工用塑料薄膜规范 第3部分:单项材料规范 活页7:对电气绝缘用氟乙烯-丙烯(FEP)薄膜要求
Specification for plastic films for electrical purposes; part 3: specifications for individual materials; sheet 7: requirements for fluoroethylene-propylene (FEP) films used for electrical insulation
1992
发表于 2010-3-19 10:49:17 |江苏| 显示全部楼层
谢谢楼主推荐
发表于 2010-6-6 15:50:11 |江苏| 显示全部楼层
谢谢楼主
发表于 2010-6-23 10:11:03 |北京| 显示全部楼层
谢谢推荐
发表于 2010-6-23 16:28:42 |北京| 显示全部楼层
谢谢 谢谢噢…………
GMT+8, 2026-10-15 16:01 , Processed in 1.038144 second(s), 8 queries , Redis On.
